I assume your 1ph lathe is 240v? If so the two 1phase legs in a RPC and most Switching converters go straight through, so in theory you could use the main 240 1ph that goes into the converter, but it will pass through the PhConv O/L's. Providing the RPC is fed from sufficient gauge wiring to avoid volt drop, it should be no problem.
Make sure you fuse it separately.
Al.
Albert E.
