Ok guys, those of you who are familiar with me, know how I like to make stuff. I have always been fascinated with hydraulics. Here is a cylinder I made from scrap material. A lot of you have lathes and making a piston or a rod or an end cap is not much of a chore. But...trying to make the cylinder with a smooth bore that is accurate is difficult if not impossible for the home shop.
My neighbor had a new deck put on the front of his house and for ballisters they used 3/4 inch round black aluminum tubes. There was scrap left over and being who I am, I saw visions of what I could make. The tubes are 3/4 inch OD... .654 ID with a very smooth bore. On the box it said this was 6061 extruded aluminum.
With this size bore and at air pressure of 100 psi you can expect about 33 lbs of push from this little cylinder, which is more than enough power to open large tool box lids, robotics, etc (your imagination is your only limitation).
The first pictures show the end caps I made from aluminum and the rear end cap and piston have been grooved to accept O rings to seal better. This is a single acting cylinder and no seal at the rod end. The rod is 1/4 inch.
The threaded hole in the rear cap is 1/8 inch pipe thread which is very common. The fitting is 1/8 inch pipe thread on one side and 1/4 inch compression fitting on the other which makes it very handy to use 1/4 inch aluminum, copper, or flexible plastic line for your air supply. The last picture shows the cylinder assembled. There is no rod end because I have not yet decided how I will apply this.
At first, I had thought I might TIG the caps on but I was afraid that I may slightly distort the cylinder from the heat. If you will notice, on the end caps, enough of the cap is inserted into the cylinder that I could pin it in place with 1/8 inch roll pins. That is why I put an O ring on the rear end cap and the pin is between the O ring and the brass inlet fitting.
One good thing about finding this resource (as far as the cylinder) is you can custom make any length you need to fit your exact need. I am going to check into a larger ballister tubes for more power.
I hope some of you will find this useful.
Nick
PS I suggest you use a small restrictor orifice at the air inlet so the rod will not slam out too fast.
