585,994 active members*
4,762 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Help with toolpath.
    Sep 2007
    32
    Help with toolpath.
    Hello.
    I'm currently trying to learn Mastercam and i have a question
    How can i machine out the part i have painted in black in the picture?
    The piece is 10 millimeters thick and the "pocket" i have painted is 5 millimeters deep.
    I have tried making a rectangle and pocketing it but i'm not getting the result i want, could anyone help me out with this?
    Also attached the mcx file if that is any help.
    thanks
    MagooT
    Attached Files Attached Files
    Apr 2003
    3578
    please review mu file Partcadcam and see how I used the contour for this option.
    Cadcam
    Feb 2006
    992
    create a geometry..... then pocket it out it work like charm.
    The best way to learn is trial error.
    Sep 2007
    32
    cadcam> Thanks! That's exactly what i was looking for could you please tell me how you did it?
    I tried drawing a rectangle, solid extrude (cut body), and then adding a contour toolpath. But it just goes inside the rectangle and doesn't extend out like yours did.
    thanks
    MagooT
    Jun 2009
    20
    Quote Originally Posted by MagooT View Post
    Hello.
    thanks
    MagooT
    is the radius of your mill larger than the radius in the corner's of your pocket? double check your endmill diameter.
  1. Help with surface toolpath.
    By M-man in forum Mastercam
    Last Post: 04-12-2007, 09:02 PM
  2. Toolpath set up?
    By Jessica in forum ArtCam Pro
    Last Post: 03-13-2007, 05:13 PM
  3. 3D toolpath help
    By Dfennell in forum BobCad-Cam
    Last Post: 02-03-2007, 08:13 AM
  4. Help needed with toolpath.
    Last Post: 12-04-2006, 02:44 AM
  5. Project Toolpath on STL
    By Sanghera in forum Mastercam
    Last Post: 03-13-2006, 01:43 AM
