585,687 active members*
4,680 visitors online*
IndustryArena Forum > CAD Software > Solidworks > Part->Block->Drawing-> Dimension
    Dec 2005
    436
    I have a model that contains a sketch that contains a block. The block repesents a piece I want to machine.
    The block within the model already has all the dimensions I want "marked for drawing"
    I would like to make a drawing coontaining the block.
    I can insert the block into a drawing.
    The dimmensions I created while within the model show in the drawing.
    But I cannot modify the position of the dimensions while within the drawing.
    Is this posible with blocks made from parts?
    I can do what I want to with parts inserted in drawings but am not as succesful with blocks.
    any advice?
    Jan 2004
    3154
    8 years of SW and I have never used a "block" (never seen any use for them - not like in ACAD).
    Can't help - sorry
    www.integratedmechanical.ca
    Dec 2005
    436
    Designing part
    I'm designing a part that moves, so it's features are dependant on adjacent components while in two poaitions.
    So I drew my block, and have an instance of the block in both positions.
    While so I modify the same block while in two places.
    I got tired of repeatedly moving, editing and then moveing back and editing again.
    So I thiiought to myself "there has to be a better way, what is that Block menu command that I always ignore, what does it actually do?"
    Do you have any suggestions?
    Jan 2004
    3154
    Not enough info.
    How about doing a save as and having 2 parts, that should resolve the conflict.
  1. Programming part variations with block skip
    By kmuller in forum PTC Pro/Manufacture
    Last Post: 09-18-2007, 10:36 AM
  2. Gerber Dimension 200
    By teemac in forum Gerber
    Last Post: 04-22-2007, 05:30 AM
  3. Is making a part as easy as drawing it in 3d?
    By randyf1965 in forum Commercial CNC Wood Routers
    Last Post: 04-05-2006, 01:23 PM
  4. RS232 program block by block
    By smoregrava in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-22-2005, 07:52 AM
  5. Angular contact flange block drawing?
    By D.D.Machine in forum Uncategorised MetalWorking Machines
    Last Post: 09-02-2005, 06:14 PM
