585,727 active members*
3,973 visitors online*
    Oct 2004
    38
    Fanuc OT Buttons dont work
    Hi
    Due to a memory problem with our lathe we had to reload all the parameters and everything is working fine except that one set of buttons dont work on the panel. This is the MDI, Single block, etc. It is weird that it is the whole cluster. If anyone could help that would be great.
    Lee
    24220
    These buttons/switches are usually provided by the MTB and are not on the Fanuc keypad, I assume you have this set up, with Fanuc buttons then the full keyboard parameter may be missing, if OEM switches, then this is usually a hardware problem, i.e. voltage missing on switches, they can be checked by looking in the diagnostic input bits.
    Al.
    Albert E.
    Check parameter 905 this turns on the pmc.
  1. Broken Buttons Hitachi-Seiki HT_20SII
    By Ken in forum Uncategorised MetalWorking Machines
    Last Post: 04-21-2008, 07:28 PM
  2. Jog buttons occasionally stick, runaway gantry
    By Brian Queen in forum Mach Mill
    Last Post: 08-30-2007, 11:35 PM
  3. Programing AUX buttons
    By George C in forum Centroid CNC Control Products
    Last Post: 02-10-2007, 08:33 PM
  4. Bridgeports hidden buttons on cncs
    By leggetmachine in forum Bridgeport / Hardinge Mills
    Last Post: 08-19-2005, 06:22 AM
