585,758 active members*
4,521 visitors online*
Thread: HSM research
Results 1 to 7 of 7
    Nov 2007
    4
    HSM research
    Hi Everybody,
    I have done my Master thesis with HSM: " Optimization the Ra (surface finish) due to changing V,S,t,R. But I can not find out any good HSM book for my basic theory. Only get HSM by download the very short researchs on Google.
    Pls let me know the difference between HSM and CNC conventional in Ra,V,S,t,R.
    Sep 2007
    217
    I have got some great extensive research done from a U.F here is the link:highspeedmachining.mae.ufl.edu/htmlsite/tutorials.html
    I hope that helps.
    Nov 2007
    4
    I can download tutorial 2,3 and 5.pdf only, others can not, which study in Chatter/ Dynamics of High Speed Machining. It is different of mine in Optimization the cutting conditions when considering the affect of V,S,t,D (tool) to the surface finish (Ra) by experimental reseach. Thanks.
    Apr 2005
    263
    katebao, let us know when your thesis is available online!
    A couple of papers by Toh et al come to mind where HSM paths are compared, maybe you know about these already?
    http://dx.doi.org/10.1016/j.matdes.2004.09.021
    http://dx.doi.org/10.1016/j.matdes.2004.07.019
    http://dx.doi.org/10.1016/j.precisioneng.2004.01.001
    http://dx.doi.org/10.1016/S0261-3069(03)00160-2
    AW
    Nov 2007
    4
    Yes,toolpath strategy is also very important to HSM, but it will be researched later,so toolpath is different of my reseach right now.
    I forcus on Optimisation for Surface finish Ra when consider the affect of spindle rpm, feedrate, depth of cut, tool diameter only.
    In next 3 months, I will do the experimental stage with Mikron machine (model: HSM 600) with different cutting conditions,then I measure the surface-finish correspond to those conditions by the optical Ra measurement device.
    Finally I used the theory of total experimentation to get the formular of
    Ra = F (feedrate, depth of cut, tool diameters)?. That is what I need to solve now.
    Thanks for your helps.
    Aug 2007
    135
    Are you familiar with all the research into surface finish LLNL did in diamond turning? They answered all the questions you are attempting to solve now.
    Predicting surface finish is a matter of asynchronous error in the sensitive axis combined with tool sharpness. All your proposed measuring conditions change either the asynchronous error of the system or the apparent edge of the tool.
    Nov 2007
    4
    Hi, I've just finish the theory of HSM for surface finish. Now, I forcus on choosing toolpath strategy, tool to do machining a sample and get result. Thanks a lot.
  1. EPS & Polyethelene Surfboard Research
    By Spearz in forum Mechanical Calculations/Engineering Design
    Last Post: 06-22-2007, 11:58 PM
  2. project research
    By ramus in forum CNC Wood Router Project Log
    Last Post: 10-26-2006, 02:59 AM
  3. have been doing some research (cnc router)
    By planescott in forum DIY CNC Router Table Machines
    Last Post: 09-25-2005, 04:13 PM
  4. Research question
    By Chunky in forum Uncategorised CAM Discussion
    Last Post: 05-29-2005, 12:02 AM
  5. Market Research
    By Andy NC in forum Uncategorised CAM Discussion
    Last Post: 07-20-2004, 10:11 PM
