585,948 active members*
3,584 visitors online*
IndustryArena Forum > MetalWorking > Bending, Forging, Extrusion... > Custom bending a custom extrusion
Results 1 to 11 of 11
    Dec 2007
    35
    I mangled the aluminum extrustion that wraps around the top of a boat windshield. Finding a replacement, new or used, appears to be, out of the question.
    Among other machine tools, I have access to a wire EDM so it's conceivable I could make an extrusion die but I have no idea how to extrude the part or how to bend it once that's done.
    Any suggestions or starting points?
    Attached Files Attached Files
    Jun 2007
    12
    To bend it you would need tooling and probably need to fill the gaps in the extrusion to prevent collapse.
    The same is true if you were to try to get someone to bend it for you - they would need to tool up
    Best bet is the original manufacturers I'm afraid.
    Dec 2007
    mangled ext
    busted rinker.
    I would try the OEM if still in business.
    You showed where it goes but not how badly mangled.
    It maybe with patience and skill be repaired.
    The next best idea would be to replace all of the top trim. Maybe not original but would all match.
    Third would be to find close extrusions and build something up to near duplicate original.
    Depends on exactly what you wnat for an end result.
    Cheers
    Dudley
    Dec 2007
    35
    Thanks for the responses.
    I suppose someone more talented than me might be able to bend the damaged extrusion back into shape but it has kinks and ripples and even a melted spot. I've worked at it some but it is very hard to match the contour of the windshield.
    I'd love to know how they do stuff like this in the first place. I'm not picky about what the cross sectional profile of the extrusion looks like. I could replace the whole thing, but no matter what extrusion I end up using I've got to figure out how to create that compound bend required to make the thing fit.
    Jun 2007
    12
    Bending its not that hard IF you have the right tooling and equipment - which would be very expensive and certainly many many times the cost of what you are trying to make. For that reason you would be better off trying to obtain one from the makers
    Dec 2007
    35
    The boat is an orphan. Company folded around 2000. I've found one outfit that supplies many of the boat manufacturers with these window frames but they didn't make it and didn't know who might have.
    Jun 2007
    3757
    Talking Fiberglass?
    Ever thought of making a fiberglass surround.
    Make a positive with a spoke shave or router.
    Make a mould. Make em whatever color you like.
    Easier than making an extrusion die.
    They usually want you to take 5 or 10 lengths so what do you do with the rest?
    Dec 2007
    what model boat exactly???
    I ebayed "rinker" and got several boats that appear similar and up to 2007.
    Maybe more eyes looking and a great picture of your mangled extrusion.
    and a good picture of the profile would help you and us in helping you.
    Cheers
    Dudley
    from my days in auto industry. Tension and bend over mandrels for curves.
    One off would be by hand and forms.
    Dec 2007
    35
    Didn't mean to mislead. I've been using "Brokenrinker" for a long time. The Rinker was my previous broken boat. The current broken boat is a Celebrity.
    Thanks for the input.
    neilw20 - fiberglass would be great but how would I make a mold for this weird shaped thing.
    These are links to some more pics . . .
    http://s214.photobucket.com/albums/c...t=extrude5.jpg
    http://s214.photobucket.com/albums/c...t=extrude4.jpg
    http://s214.photobucket.com/albums/c...t=extrude3.jpg
    http://s214.photobucket.com/albums/c...t=extrude1.jpg
    http://s214.photobucket.com/albums/c...t=extrude2.jpg
    Dec 2007
    extrusion possible source.
    bumbling around I googled and found a review on a new boat with the same windshield manufacturer as your boat.
    try their customer service and explain your issues.
    you may be able to get a piece from baja boats or they may link you to their supplier.
    http://www.boats.com/news-reviews/article/fine-latitude
    some other possibly useful links
    http://forums.iboats.com/showthread.php?t=220264
    http://www.iboats.com/Marine_Store/dm/prod_id.52313
    Cheers
    Dudley
    Dec 2007
    35
    69ddbl - that's some pretty good bumbling. I've been looking around for months now and had found zero references to any other OEMs using Vision2000 windshields. Now if I can find a sympathetic ear at Baja Marine . . .
    Thanks!
  1. Custom DNC w/210i PLC
    By bannerman in forum Fanuc
    Last Post: 12-03-2015, 11:00 PM
  2. Help with custom JOG
    By chris59 in forum Mach Wizards, Macros, & Addons
    Last Post: 12-19-2005, 10:57 PM
  3. Custom documents?
    By duluthboat in forum FeatureCAM CAD/CAM
    Last Post: 02-18-2005, 03:05 PM
  4. Custom 5-Axis?
    By jcolley in forum Knee Vertical Mills
    Last Post: 01-13-2005, 02:09 AM
  5. custom tooling
    By CNC Pro in forum OneCNC
    Last Post: 04-11-2003, 04:36 PM
