Hi all
Can any one tell me how to take SRAM backup or all backups i need to take on fanuc 18i
Hi all
Power off the control(just control not the whole machine).
Press the far right arrow key and the key immediately to it's left and continue to hold as you power on the control.(Buttons directly underneath the screen)
A selection screen will appear. Press the button corresponding to "Down" until you get to SRAM and press the select key. A new screen will appear.
Scroll to "CNC--->Memory Card"(should be highlighted as soon as the screen opens) and press Select. A confirmation message will appear "Are you sure?" Press "Yes" or "No".
Once the data is loaded to the Memory card you will be asked to press the "Select" key. Then press the button corresponding to "Down" until you highlight "END". Press "Select".
Once you press select you will be taken to the main screen, again scroll down to end and press select. The control will boot up as usual.
Thank you
