585,665 active members*
3,375 visitors online*
Thread: X axis Fault
    Dec 2004
    167
    X axis Fault
    We have a Fadal VMC15 and are getting the following error at power up.
    X axis Fault
    Error #1
    Motor Overload
    We switched the X and the Y amp card and get the same message. What should we try next?
    Thanks for any help anyone can give us.
    Dec 2004
    167
    I took the X axis resolver and swapped it with the Z and the problem went away. Switch them back and the problem comes back. Any body have any ideas?
    Dec 2004
    167
    A new motor fixed the problem.
    900
    The VMC 15 has DC servo motors. You can replace the resolver with out replacing the motor. The error code #1 means no feed back signal from the resolver to the controller card.
    Neal
  1. C axis fault
    By Konstrukter1 in forum Fadal
    Last Post: 02-09-2020, 10:40 AM
  2. Amplifier fault on X axis.
    By Paul Petersen in forum Fadal
    Last Post: 09-06-2007, 04:43 PM
  3. Z Axis Drive Fault
    By jeremy_d in forum Servo Motors / Drives
    Last Post: 08-16-2006, 04:04 AM
  4. C axis fault
    By Rudee in forum Fadal
    Last Post: 05-13-2005, 05:58 PM
  5. Axis Drive Fault
    By Bluey in forum DNC Problems and Solutions
    Last Post: 11-04-2004, 01:54 AM
