585,981 active members*
4,470 visitors online*
    Aug 2007
    motor setup help ????
    Hello all,
    I am in the process of setting up mach3. I have set up all my input and output data and am able to spin all the x,y and z motors using the MDI screen.
    My issue is with the "motor tuning" screen. I'm not sure what value to input for the "steps per" field. The info for my machine is as follows:
    -using a 4.29:1 gear reduction
    -running the gecko's at full step
    - rack and pinion grear is 0.750" DP on a 20TPI rack
    I have calculated 1step = .0027 " per step final drive ( .0750*3.14/4.29/200 )
    What value should be entered in the "steps per" field as i am not sure what this unit is asking for !!
    thanks for any help in advance !!!!
    Use the axis calibration on the settings screen, just above the reset button.
  1. Output of Encoder of Servo moto??
    By Thinh VN in forum Servo Motors / Drives
    Last Post: 07-08-2007, 06:09 PM
  2. What's your setup like...
    By Scratch in forum Waterjet General Topics
    Last Post: 01-12-2007, 08:31 PM
  3. What is your setup?
    By dolanosa in forum CNC Wire Foam Cutter Machines
    Last Post: 10-09-2005, 08:00 AM
  4. Moto GP back in the US! Anyone going?
    By Rekd in forum Community Club House
    Last Post: 03-03-2005, 11:52 PM
  5. Anyone know anything about this setup?
    By efreak in forum DIY CNC Router Table Machines
    Last Post: 08-29-2004, 06:27 AM
