I have been operating an Bavalloni 315n on granite,marble,limestones sandstone.I have been mostly self taught as my 2 weeks training i was supposed to have turned out to be 3 or 4 days.
We produce mostly granite worktops from polished bowls with drainer grooves and taps to the full recessed drainer compleatly covering the bowl and drainer grooves,shape and polish eg grinding work but the lines left by the tools is not to the standard that is required and so is finished by hand ,i know there is a tool out to solve this problem which is basicly a gear box with cup type tool to scrub the lines out but this is only going to work on straight edges and can not be used on any kind of shapes.
The tools that i have used to try and solve this problem have been the ossilating type with limited results.
Any thoughts on this.
There is only one other question at the moment, vaccum tank pipes freezing .
I hate running back and forth with keetles of hot water trying to get rid of that plug of ice in the vacum pipe before the job starts moving while i am trying to operate the machine,its getting cold again so that problem will return as soon as we get our first frost.any thoughts on that as well people
I'am sure there will be loads more to ask you all many thanks
