585,908 active members*
3,680 visitors online*
Page 2 of 2 12
Results 21 to 27 of 27
  1. #21
    Jan 2006
    461
    I will tell you right now that optical switches are not immune to noise. That is simply not true. I use the optical switches from Industrial Hobbies and am having the same problem as yall are. IH's solution was to make sure everything is grounded properly, and if that doesnt work, to use a resistor from each input to ground. A 1/4w 100k or 1000k is what they recommend I believe. I will say that the optical switches are just freaking amazingly accurate. And IH's are beautifully made.
  2. #22
    May 2006
    1469
    Quote Originally Posted by pzzamakr1980 View Post
    Well in fact they probably are.
    However there is more to connecting them up than just the switches. Lots of other opportunity for noise to make it's presence felt between the switch and the software.
    Greg
  3. #23
    Jun 2003
    2103
    pzzamakr please note I said I didn't know if the statement was correct, but that I would find out. Sounds like you already have. I am curious about the IH switches. I am trying to build my switches now because I couldn't find the IH switches. Are they still available? I looked on their site again last night and could not find them listed???
    Mike
    No greater love can a man have than this, that he give his life for a friend.
  4. #24
    Jan 2006
    461
    Yeah, just call em. Gene is great and I'm pretty sure he said they were available for purchases seperately from the system. But dont take my word on it. And yes, I should have been more specific, the switches themselves are immune, but since you have to wire them, connect them, etc. etc, they are then not immune.
  5. #25
    Mar 2006
    48
    Quote Originally Posted by Mr.Chips View Post
    I’m still working on my first project, a Chinese symbol meaning Happiness for a friends wedding. So far it has not been bringing any happiness into my life. But like I said this is my first project and just going through a period working out the bugs.
    Hi, I just saw this posting and simulated your Gcodes. If it is not yet finished, you may want to edit it. The 1st horizontal line should be longer than the 2nd horizontal line. In other words, you reverse the 1st and 2nd line's length. Also, traditionally, you put two of those side by side to mean "Double Happiness" as it means bringing happiness to the 2 families of the couple.
    Hope this helps.
  6. #26
    Re: Limit Switch Triggered! IS NOT!!
    +1
  7. #27
    Jul 2018
    11
    Hi All,
    Thanks for sorting one problem but I have another, I have tried wiring my limit switches to my Geko 540 one wire to outlet 1 and the other to common but can't get it to work what have I missed??
    Mike
Page 2 of 2 12
  1. "limit switch triggered" aleatorio en Mach3, Ruido?
    By lamartinada in forum Spanish
    Last Post: 11-20-2013, 07:28 PM
  2. Replies: 3
    Last Post: 09-30-2013, 08:55 AM
  3. limit switch triggered
    By Claude Boudreau in forum Machines running Mach Software
    Last Post: 04-29-2012, 01:06 PM
  4. limit switch triggered issue
    By 15mgtar in forum Mach Software (ArtSoft software)
    Last Post: 10-19-2009, 09:25 AM
  5. Limit Switch Triggered??
    By H2ODiver in forum Mach Mill
    Last Post: 02-22-2007, 06:48 PM
