Hi All,
Finally got my VQC (Mazatrol CAM M-2) inside and running. However due to the long time that it sat with no power I had an alarm 22 and had to reinitialize. This means that most of my parameters were shot. However I have about 3 different parameter sheets and all of them are slightly different. Once I did get some parameters in I tried to zero return the Z but only ended up crashing it in the + direction. I then attempted to do it on the X only with the feedrate turned way down. This also eventually resulted in a similar alarm condition only softer.
Could anyone tell me what parameters control the Machine Zero Return? I am becoming aware that this machine doesn't work like most I have used. It is all software stops rather than limit switches, correct? I feel I have a big learning curving ahead of me.
Also what is the correct procedure for zeroing the axis? Possibly I am not doing something right and the problem is not a parameter?
