I heard that it is possible to download parameter lists from the MAZAK site. Is it true ? and where do we go to download them because I haven't seen it on their site.
Denis Paradis
[email protected]
Denis Paradis
[email protected]
what your Mazak model?
AJV 3560 1987 CAM M2 controller. I need the parameter list for the pallet changer. We can't get the pallet to change.
[email protected]
You should just need to M Codes to do a manual pallet change. They should be in the M Code list in the operator manual. M71 calls pallet #1 M72 calls pallet #2, some machines use M911 and M912. If you need a complete listing of the M Codes let me know, I could send it to you.
What is exactly is the problem with your pallet changer? Are you stuck in some weird spot? Command doesn't execute? It stops in mid-change? It doesn't start at all?
If you're stuck, you also have solenoids on that machine you can force without parameters. But this all depends on what your "pallet changer problem" is...
It's just a part..... cutter still goes round and round....
