Anyone received the S0 manual ?
Hope to have a copy.
Please email to [email protected]
My shop just purchased a Deckel SO cutter grinder 36-26156 from an auction. I am responsible from learning and then teaching the proper operation. I can't seem to find and operators manual anywhere. If anyone has a copy they can e-mail me that would be much appreciated. [email protected]
If anyone has a copy of a Deckel SO cutter grinder operating manual,they can e-mail me that would be much appreciated. [email protected]
Hi everyone,
I see there are one or two generous offers of the User Manual,
any chance I could blag one also! (preferably in English)
Would be appreciated.
Email addy is
g6paj2 at yahoo dot co dot uk
Regards and Thanks :cheers:
RichardJG
hi Matt
I am new on the cnc . i have a second hand deckel so and will be very please to get the manual; My email [email protected] thanks a lot
Matt,
I have one of these cutter grinder's.
I sure would like the manual to get it ot work.
Could you send me one?
Thanks Rod
[email protected]
I would very much appreciate a copy of the manual for SO grinder as well as any other info you may have.
My email = [email protected]
Thanks you very much.
Hi Matt,
I have just joined this forum as I am a 'Newbie' to engineering, although I have watched my father and also my friends turning on a lathe in the past.
I am over in the U.K and have a South Bend 9A lathe, and a small milling machine.
As I have a number of Tool bits and mills that require sharpening I have recently purchased a Grinder. Mine is an Alexander model, which was a direct copy of the Deckel SO machine.
In order to use it properly, could you please e mail me a copy of your Deckel manual?
Many thanks,
Del.
E mail : [email protected]
Matt
Could I get a copy of the SO manual in pdf. Thanks so much. You really help the community with your generous offer.
Rick
[email protected]
Hi
Please send me a pdf copy of Deckel SO cutter grinder manual. [email protected]
Karunakaran
I would also like a pdf copy of the manual. Could someone send one to young-at-last1.com
I would like to get a copy. Could anyone please send a copy to young-at-last1.com?
Thank you.
Hi Matt
I've just joined this forum. Could you possibly send me a copy of Your Deckel SO manual along with your other attachments. If you still have them that is after all this time.
Or failing that if theres any body else on this forum that has the files it would be greatly appreciated.
[email protected]
thank you in advance
regards
Paul
Thank you everyone who responded. In super quick time
regards
Paul
Hi, is this manual still available?
thanks,
Rick
[email protected]
Hi Matt: I am responding to this very old offer (2008), but if you are still active and the Deckel SO manual is still available, I would very much appreciate a copy.
ianmoss at shaw dot ca
Thanks,
Ian
Deckel SO manual (Similar machine is OPTI grind GH20T)
http://neme-s.org/Shaper%20Books/DEC...STRUCTIONS.pdf
Hi Matt,
I would also like a copy of the Deckel SO manual and anyother info that you may have.
[email protected]
Thanks,
