585,599 active members*
3,560 visitors online*
IndustryArena Forum > MetalWorking Machines > Syil Products > HELP: 4th Axis configuration (video posted)
    May 2005
    925
    Question HELP: 4th Axis configuration (video posted)
    I have a some questions regarding the 4th axis configuration:
    - what is the standard for setting Zero in this axis? in one of the extremes of the screw or in the middle?
    - how do you reference this axis at startup?
    - the 4th axis is supposed to go around 360 or a little more? (or a little less?) Using my "eyemeter" it seems its some degrees short of 360º
    I machined a wood piece and made a small video (will upload in next post) but I didn't finished the piece because of these doubts.
    Thanks in advance
    May 2005
    925
    As promised the video: http://www.veoh.com/videos/v1635783c7ehCSnW
    :rainfro:
    Sep 2006
    203
    Zero of a A is usually your Z axis 0 plane, or 0 degrees.
    Their is no referance on the Z.
    The A can go around any number of degrees you specify. 720, 1023, 20, etc. One full revolution is 360 degrees.
    Direction, Commitment, Follow Through
    May 2005
    925
    sorry, wrong post (chair)
  1. Question About 4th Axis Configuration
    By Khalid in forum DIY CNC Router Table Machines
    Last Post: 02-27-2009, 06:52 PM
  2. best bearings configuration for z axis for manual wood joint maker
    By endgrainguy in forum DIY CNC Router Table Machines
    Last Post: 08-20-2007, 02:10 AM
  3. Axis configuration, please help.
    By alexccmeister in forum MetalWork Discussion
    Last Post: 06-25-2007, 11:38 AM
  4. Configuration Of Output Pins In Parallel Port FOR 4 AXIS
    By Khalid in forum Open Source Controller Boards
    Last Post: 05-20-2007, 07:55 AM
  5. Need help with axis configuration
    By jetijs in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 08-24-2006, 11:06 AM
