586,009 active members*
4,834 visitors online*
    Mar 2005
    271
    x axis will only move one direction
    Last night all axis' were working fine,today i went down and homed the machine but x axis crashed it wouldnt home,now i did change the steps per inch in the motor config.Both Z and Y were fine.But now when I try to jog the x axis it will only move in the negative direction using both + and - jog buttons. Any help would be appreciated.Thanks
    Feb 2007
    498
    check all your pin numbers for the x axis,make sure they are correct,next check the key
    assignments for the x,maybe you changed them by accident,also check the limit switch
    you crashed into,maybe its stuck or shorting,just a thought
    Mar 2005
    271
    Its now fixed,I played around with it and now it works,the only problem is I dont know how I fixed it,or what was wrong!
  1. What method did you use to move the x-y-z axis?
    By widgitmaster in forum Polls
    Last Post: 07-04-2013, 04:49 AM
  2. G91 B axis move?
    By DocHod in forum G-Code Programing
    Last Post: 11-02-2007, 05:56 AM
  3. How do you move an axis manually ?
    By Eurisko in forum DIY CNC Router Table Machines
    Last Post: 04-07-2007, 03:00 AM
  4. Reverse axis direction?
    By saturnnights in forum Machines running Mach Software
    Last Post: 03-29-2006, 03:40 AM
  5. Mach 1 x-axis will not move
    By Redline in forum Mach Software (ArtSoft software)
    Last Post: 07-05-2005, 06:01 AM
