585,758 active members*
4,675 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > Rebuild of Sanyo-Denki 750W servo possible?
    Aug 2005
    62
    I sometimes get S-D servos very cheap but this time I think it is something mechanically wrong with one.
    It makes more noise than a good one when powered, I can't feel any slop in the bearings but I haven't been able to test it under load.
    Is it possible to take it apart to take a look without ruining it?
    I'll propably end up paying between 30 and 50 dollars for it so it's no big del, I just want to know if it's possible to fix it in some way?
    thanks
    /Daniel
    24220
    What makes you think there is something wrong mechanically? with a BLDC or AC type there is nothing much mechanically other than bearings.
    In some cases with BLDC types, commutation defect or wrong phasing can cause what appears to be mechanical noise.
    Al.
    Albert E.
    Aug 2005
    62
    I have tried an identical servo with the same setup and there is a marked difference in the noiselevel.
    Also the noisy one looks more battered and has propably seen heavier use.
    Maybe it's one of the bearings after all.
    Aug 2005
    62
    I bought it anyway for about 40$, I'll see if it holds up!
  1. Sanyo Denki Help
    By Gary D in forum Stepper Motors / Drives
    Last Post: 06-30-2012, 06:10 AM
  2. Sanyo-Denki Servo Motor Handbook & Sizing
    By Al_The_Man in forum Servo Motors / Drives
    Last Post: 07-06-2007, 02:02 PM
  3. Brake rebuild
    By hmc710 in forum Bridgeport / Hardinge Mills
    Last Post: 07-03-2007, 04:33 AM
  4. Haas Vf-2 Rebuild
    By DEAN in forum Haas Mills
    Last Post: 09-19-2005, 04:46 AM
  5. Router Rebuild
    By Ursine in forum DIY CNC Router Table Machines
    Last Post: 08-18-2005, 02:42 PM
