Originally Posted by
Apples
Damo,
I have a hypertherm powermax 1000 with the machine torch for the cutting table. I can cut anywhere on the sheet of steel up to 10mm. Anything else I have to do an edge start or drill a hole. If I do an edge start hypertherm have a reccomended cut capacity of 19mm, with a maximum of 25mm.
I think that if I end up cutting much steel over 1/2" or 12.5mm I will rig up an oxy. This has a straight cut regardless of the thickness of the steel being cut.
Cheers
Peter
I bet the Hypertherm cost you a packet!
Sorry if this is a bit OT but I have been trying to track down a machine torch for my oxy/acet setup. Any idea where I can get one from without having to sell one of my kidneys???
Damo.
Damen Stevens
Brisbane, Australia.
"Measure, then cut, then swear, then measure & cut again"
http://www.cnczone.com/forums/showthread.php?t=13958
