585,712 active members*
4,233 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Tool radius comp
Results 1 to 6 of 6
    Jul 2004
    59
    Tool radius comp
    Could someone explain me what is the difference between compensation type of the tool (Off, Computer, Control, Wear, Reverse Wear) ? What should I use in order not to use G41 or G42 (for lathe) or to input in the tool offset the radius value of the insert. I wouldn't came up with such a basic question, but the "Lathe training tutorial" book does not refer at all at this subject.
    Thank you
    Jun 2005
    232
    Computer calculates the tool path based on the tool nose radius.
    Control calculates the tool path using a tool with no radius.
    So you have to input the radius and the radius location in the machine.
    If you want to use g41 or g42 use control.
    If not using g41 ,g42 use computer but make sure when you select the tool your using it has the same tool nose radius your using. I always use computer for lathe work.
    Tim
    Jul 2004
    59
    Thank you Tim, you clarified my dilemma.
    Jul 2004
    59
    One more thing...
    Why when I try to run a canned cycle on the lathe, I can't choose "Computer" option but only "Control", otherwise I get "Stock collision" alarm?
    Apr 2003
    3578
    What version of MC are you using?
    Cadcam
    Jul 2004
    59
    MCX
  1. G143 Nose Radius Comp. - Hitachi Seiki HT23J
    By jbird68 in forum G-Code Programing
    Last Post: 05-07-2021, 01:00 PM
  2. tool nose radius comp
    By joe1970 in forum G-Code Programing
    Last Post: 02-25-2010, 04:43 AM
  3. Fanuc 11m Tool Comp
    By Jfrahm in forum Fanuc
    Last Post: 07-29-2007, 11:01 PM
  4. tool nose comp.?
    By pp-TG in forum MetalWork Discussion
    Last Post: 09-19-2006, 09:36 PM
  5. Tool Comp not working in Mach3
    By Dennis Fletcher in forum Mach Software (ArtSoft software)
    Last Post: 03-09-2006, 03:24 AM
