I am relatively familiar with setting up and running Mach 3 Mill on single spindled machine. Does anyone have any experience on setting up Mach 3 to run multiple spindles?
I realize I can change my offset for the X and Y difference from the primary spindle, but what is the best way to turn the other spindles on or off?
The machine I am considering for a retrofit has 3 router spindles. They all use the same variable frequency drive, so I need to select different ouputs for the motor contactors, but the speed control is the same for all of them.
Any ideas would be greatly appreciated
