585,931 active members*
4,966 visitors online*
Results 1 to 6 of 6
    270
    Vcarvz now posts G-code
    Vcarvz is a text layout and 3D V-cutter carving program. It incises Tru-type text outlines, and will also alternate between incised and relieved contours within a flat DXF contour file. This software tool was originally designed as a supplement to VectorCad-Cam. It is still optimized for use with Vector, but can now also be used with any CNC G-code controller. No intervening Cam programming step is required.
    The code is generic and has been tested to work directly within DeskCNC. The DeskCNC editor can simulate the actual V-carving as a rendered 3D surface, running the complete program or single/multiple block stepping.
    Sample DeskCNC cut file simulation image here: http://www.imsrv.com/6x3ovalVcarvz.jpg
    The upgrade is free to all previous Vcarvz customers. A 30 day demo is available for download at http://www.imsrv.com
    Fred Smith - IMService
    Apr 2003
    1079
    I would like to try the software, but I have been waiting all day for the email with the download link to arrive! Should it take so long?
    edit - ok, got it now!
    Apr 2003
    1079
    Just had a quick go with the software, and have to admit, I like it!
    It is gonna take me a while to get it to produce some clean g-code, I had a few problems with my imported DXF, the code had a few places where it cut the same section twice, particularly on the dot of the letter "i". I am sure this is my fault, I will keep trying. I would also like to see a final finnishing pass, since I had some deep lettering, I cut in three passes, and those are clearly visible on the finnished product. Again, this can be overcome by creating a second code-set at full depth and running after the first set so I am not too worried.
    Just thought I'd give it the thumbs-up and show my first cuts, thanks Fred
    6855
    Nice job maybe a review is in order?
    Nov 2003
    299
    One question.
    The demo program produced a cut file where the bit was plunging alot. Is this normal? Seemed to do this mostly on curves. Is there a setting I have wrong?
    I was using Arial Black text.
    270
    That's two questions.
    1) no
    2) yes
    Vcarvz support forum is at http://www.imsrv.com/discus
    Increase filter parameter, and possibly text smoothing settings. Keep smoothing as low as possible and still retain smooth curves.
  1. parametric programming
    By Karl_T in forum CamSoft Products
    Last Post: 05-24-2005, 08:58 PM
  2. authorizing code
    By crow in forum Autodesk
    Last Post: 02-12-2005, 09:19 PM
  3. I need sample G code program
    By bunalmis in forum G-Code Programing
    Last Post: 08-24-2004, 09:50 AM
