585,962 active members*
3,741 visitors online*
Results 1 to 12 of 12
    Nov 2007
    34
    vector art 3D sample
    i cut this with my rockcliff cnc and a toshiba laptop with a pcmicia parallel port. the results speak for themself.
    i used vector machinist and mach3.
    it was cut with cheap bits on mdf so i can test the system.
    Very nice. the Vector Art 3D files are really great. I have a variety of them myself. I only wish I had the money to buy them all at once!
    Apr 2005
    438
    Small gift
    Copied this idea from another thread. Bought the rope and marine emblem from http://www.vectorart3d.com/. Cut with a 3/32-inch ball nose in one pass with 10% overstep.
    Still need a bit of touch up sanding and plan on giving it a metal bronze finish with paint from hawkeyeshobbies.
    Mar 2009
    8
    I have Mach 3. What software do I need to be able to buy and run the vector art? I mean what type of cad/cam program do I need? Thanks for your help.
    May 2006
    1469
    avirostick
    Go to the vectorart3d link provided above.
    They sell 3D artwork that you can machine with the free software they provide.
    This software will only machine files bought from their site. It is a cut down version of Vectric Cut3D. All the Vectric products are excellent.
    They also offer a few free sample 3D files to try it all out.
    Greg
    Mar 2009
    8
    Thanks. So all I need is Cut 3d and the dxf image(vector 3d art), and I'm good to go?
    You don't even need Cut3D. Just download the 3D machinist.
    http://www.vectorart3d.com/machinist_free/
    May 2006
    1469
    "Cut3D" is the software that you can buy from Vectric.
    "Vector Art 3D-Machinist" is software that Vector Art 3D provide for free to produce toolpaths for the artwork they sell. It only handles their artwork.
    Cut3D will cut the same artwork plus many other types of 3D model. But it is not free.
    Cut3D is excellent software and you may consider purchasing it.
    However I suggest that if you are wanting to purchase artwork from Vector Art 3D then try their free software first.
    Greg
    EDIT: I am a slow typist and Gerry posted while I tapped.
    Jun 2009
    7
    Quote Originally Posted by lovebugjunkie View Post
    Which machine did you use to make this?
    Jul 2003
    114
    It looks like a ROMAXX to me. www.romaxxcnc.com. Looks like a nice machine.
    Russ
    Mar 2010
    168
    V3D Problem
    Hello, I have a problem... new to CNC, just finished my build, running Mach3 and testing machine for 3D work using VA 3D Machinist. I have successfully cut 2D using Cut2D....
    THE PROBLEM: I downloaded a sample file The Flur'Dele ( not spelled right ) I watched the tutorial for Cut 3d, then loaded the file, set everything up and generated the G-Code, for the Finishing Tool Path ... I am cutting in 2 inch pink foam so I didn't need a roughing path. I zeroed my machine and checked my soft limits etc. then regenerated my tool paths. I started the cycle and the cut started... but didn't look quite right...how every it then seemed to get on track everything seemed to be going fine... the machine was cutting perfectly and the carved image was coming out fine. when it was about 95% done, the cutter lifted and moved around a bit irattically... then dropped into the carved image... and made a few quick passes... lifts & drops and ruined the carved image... then it lifted up and went to a position as if it haad gone home... but was actually about 3 Inches off of its correct Y Axis position.. I have attached the Cut3D file and the tool path code...can anyone tell me what I've done wrong? I think the machine is fine... it's something I'm doing. all help is much appreciated.
    Paul Imacman, Newfoundland
    PS:... can someone send me some G-Code for a 3D image that I can carve/test?... I would like to do a test cut in the 2" foam I have.. maybe something that I can cut with a 1/4" ballnose cutter about 6" X6" 1" deep? that way I can test using a known file that is good? Thanks
    Attached Files Attached Files
    May 2012
    13
    3d models for cnc
    STL models here
    Attached Thumbnails Attached Thumbnails 1.242.jpg   1.243.jpg   Corbel for cnc.jpg   pad on furniture.jpg
  1. Vector
    By fpworks in forum Uncategorised CAM Discussion
    Last Post: 06-06-2007, 07:01 PM
  2. Vector
    By noise in forum Uncategorised CAM Discussion
    Last Post: 11-11-2006, 12:34 AM
  3. Anyone using Vector Cad
    By BCwanderer in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 11-12-2005, 01:37 AM
  4. Vector Cad Cam
    By BeerFizz in forum Uncategorised CAM Discussion
    Last Post: 12-13-2003, 08:52 PM
