585,683 active members*
4,774 visitors online*
Results 1 to 6 of 6
    Aug 2005
    191
    Mach 3 tool touchoff
    I was impressed with the touchoff demonstration video on You-Tube which used a piece of circuit board (top side conductive) and a Mach 3 macro to zero an installed tool to the top of the workpiece. I poured over my Mach 2 pdf manual, but can't find the feature. I have the same button on my screen, but is this for something else, or am I missing something?
    In the video, the operator simply clicked the mouse on a screen button marked "auto tool zero" and when the tool slowly came down it stopped dead at the surface, put 0.0000 on the DRO, then backed up to a safe Z height. Evidently it also adjusted the DRO for the thickness of the circuit board. Can I get this feature in Mach 2?
    You should be able to do it. You'll need the Mach2 screen designer, though, to add the vb code to the button. you might be able to get it from the ftp site at www.machsupport.com
    Instructions are here.
    http://www.cnczone.com/forums/showthread.php?t=36099
    Sep 2006
    135
    Auto Tool Zero
    I also viewed the YouTube videos on the Auto Tool Zero. I am using Mach3 V3.0. When I select "Auto Tool Zero" in the status section I get "Not Yet Implemented" message. What do I do to enable? (You probably figured out I'm fairly new to Mach3). Also does anyone have details as to how to make the touch pad and how to hookup to Mach3?
    Read through the other thread I linked to above.
    May 2006
    1469
    Quote Originally Posted by dgoddard View Post
    Dgoddard
    Did you send me a message on YouTube? I have been trying answer but I keep getting an error.
    Just go to the link that Gerry posted.
    If it was not you then just disregard this.
    Greg
    Sep 2006
    135
    Yes, sent them prior to looking in CNCZone. Your emails came thru on YouTube. Thanks for the reply.
  1. Mach- Improved tool path display ( see video)
    By ynneb in forum Mach Software (ArtSoft software)
    Last Post: 03-06-2014, 02:12 AM
  2. manual encoder for Z axis touchoff
    By diecutter in forum Hobbycnc (Products)
    Last Post: 12-09-2007, 05:52 PM
  3. Confused: Mach Turn, Mach Mill, Mach 2/3 ?
    By CanSir in forum Mach Software (ArtSoft software)
    Last Post: 02-16-2007, 11:41 AM
  4. anyone use mach 3 with a automatic tool changer ?
    By Bill Wann in forum Machines running Mach Software
    Last Post: 07-27-2006, 10:07 PM
  5. Tool offsets with Mach 3
    By TPPJR in forum OneCNC
    Last Post: 02-27-2006, 05:06 AM
