Originally Posted by
keebler303
..... It might also require a second drive wheel on the outfeed as it would mess up the continuous surface finish when the tube passed the drive roller and there was nothing pushing it through.
Matt
With a tube I would be tempted to devise some kind of pusher rod that had an extension to fit inside the tube and an OD the same as the tube. This way you could carry the tube through the sander without any wobbling or pausing.
