585,938 active members*
3,682 visitors online*
    Jan 2007
    15
    hydraulic help
    First of all if this is not the right place for this let me know. I am fabricating a foam spraying unit to spray open cell foam i have a gun for spraying the foam but I am lacking the pump system. What I am wanting to do in use 2 hydraulic pumps to pump the foam componets. I am wanting to use the hydraulic pumps one because of the cost and two i need to have at lease 1200 psi. So do You guys think I can get away with using them for this. I welcome all your ideas.
    Bert
    Jul 2005
    12177
    I think you had better do a bunch of testing. My experience with the chemicals for the poyurethane two part foam is that they are corrosive. Also curing reactions can be triggered by contact with some types of metals such as nickel or copper so you could find things gumming up inside the pump.
    What do commercially available systems use?
    Jan 2007
    15
    other pumps that are uses out their a piston and gear pumps that i know of, i planed on using a aluminum hydraulic pump. also the reaction done not take place in the pump but the gun
    Jul 2005
    12177
    It is not the reaction between the two chemicals I am talking about it is a reaction that might occur between the metal of the pump and either one of the two chemicals separately.
    An all stainless steel pump would probably be okay but regular hydraulic pumps are just alloy steel gears may not. Also you need to check whether the seals in a regular pump are okay.
    I am not saying a regular pump will not work just suggesting some things you consider test before going the the effort of building something and then finding out there are problems.
    Jan 2007
    15
    ok i see what you were saying, i miss read what u wrote
  1. Hydraulic valve choice
    By Robin Hewitt in forum Mechanical Calculations/Engineering Design
    Last Post: 11-08-2007, 12:57 PM
  2. Hydraulic Problem
    By bherr in forum Bridgeport / Hardinge Mills
    Last Post: 06-28-2007, 10:07 PM
  3. Hydraulic spindle?
    By Nivea in forum DIY CNC Router Table Machines
    Last Post: 06-18-2007, 06:47 PM
  4. Which Hydraulic Oil do I use?????
    Last Post: 06-13-2007, 02:01 AM
  5. hydraulic chuck
    By Runner4404spd in forum Mini Lathe
    Last Post: 02-11-2007, 11:46 PM
