585,948 active members*
3,709 visitors online*
    Nov 2007
    87
    Jerky Movement - Syil X3 Mach 3
    Hello,
    I had my X3 machine all set up using mach3. Things were nice for one day. Then after several reinstalls and unit resets things are back to normal. Now, when I run a cnc program, the machine moves in bursts, not smooth movements. Is there some sort of command duration or movement thing that is out of whack? It moves about 2mm then stops, then 2mm then stops. My z is considerably slower than the x and y. All the motor tuning values are the same.
    Frustrated Newbe,
    Joe
    Jan 2007
    869
    I would call Richard at Syil America right away. I had the same problem when I got my SX3. One of the circuit boards went bad during shipping. I had a new one from Richard in 2 days and it fixed my problem.
    Wade
  1. Mach 3 Jog movement question
    By Drakkn in forum Mach Software (ArtSoft software)
    Last Post: 11-30-2007, 11:21 PM
  2. Jerky Movement
    By elogicca in forum Mach Mill
    Last Post: 11-22-2007, 03:19 AM
  3. New W.XP and Mach 2.48 no movement
    By hugo carradini in forum Machines running Mach Software
    Last Post: 10-14-2007, 05:44 PM
  4. Jerky Movement on Interact 1 MK2
    By palikalsi in forum Bridgeport / Hardinge Mills
    Last Post: 04-27-2007, 11:41 PM
  5. Jerky Z axis????
    By bill south in forum Benchtop Machines
    Last Post: 09-10-2006, 03:33 PM
