584,841 active members*
4,285 visitors online*
Results 1 to 7 of 7
    Apr 2006
    266
    fiberglass gas tank and leaking.
    been doing some trial and error over the past few months on polyester and vinylester resins. I have found that in making my fiberglass gas tanks that the fibers are being eatten away even with a liner of Kreem or Red Kote. My only other thought is to go with an epoxy resin and the liner. Has anyone else delt with this and if so what did you do.
    Oct 2007
    62
    epoxy is a real workhorse when it comes to chemical resistance. For exemple, fiberglass tubes for the petro/chemical industry comes with an epoxy rich inside layer. I would suggest to create an inside "gel coat" with only epoxy
    Apr 2007
    40
    Be sure to check with the resin manufacturer (not just the re-seller) as most resins are not suitable for fuel tank use. Even with the apparant "ideal" nature of epoxy for tanks gasoline will usually win out in the end for eating away at epoxy. Several boating web sites have reported problems of this type. Check the West Systems (Gougen Brothers) website http://www.westsystem.com/
    Dave
    "updates always change the feature you need most. "
    Mar 2004
    1661
    Dunno that, check the epoxi type (low molecular is better) and post heat the laminate to maximize properties.
    Jun 2008
    130
    Try truck bed liner. The spray-in stuff, like.
    Sep 2003
    1113
    Built a 150 Liter diesel tank. Used epoxy and then painted the inside with red then white CARBOLINE 2 part (epoxy) paint. The red helps telegraph any holidays when you put on the white. Works like a champ! You'll have to look for the source for the Carboline - but as I understood its an "industry standard" for fuel tanks. Maybe Wicks Aircraft supply or Aircraft Spruce? (the company).
    Be sure and pressure test at about 5 - 10 psi-- if no leaks -- you're done!
    :cheers: Jim
    try this on for size:
    http://www.carboline.com/locations.aspx?showmap=us
    Experience is the BEST Teacher. Is that why it usually arrives in a shower of sparks, flash of light, loud bang, a cloud of smoke, AND -- a BILL to pay? You usually get it -- just after you need it.
    Apr 2007
    23
    RaceComp make carbon tanks with pre-preg carbon, autoclave cured. If you use the correct epoxy you will have no problems will petrol, Methanol or Nitro Methane.
    Here are few of our tanks.
    Attached Thumbnails Attached Thumbnails triumph-2.jpg   triumph-1 1.jpg   IMG_2990 1.jpg   racecomp_0350.jpg
  1. Has anyone tried fiberglass?
    By Tom Brown in forum Open Source CNC Machine Designs
    Last Post: 03-10-2009, 12:24 AM
  2. Cutting fiberglass
    By inertialabs in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-21-2008, 07:34 PM
  3. Coolant leaking slowly on back of VF3
    By Rocko1 in forum Haas Mills
    Last Post: 12-07-2007, 12:38 AM
  4. Air/Hydraulic leaking problem??
    By bherr in forum Bridgeport / Hardinge Mills
    Last Post: 06-20-2007, 04:50 AM
  5. Anodising tank
    By Julian M in forum Material Machining Solutions
    Last Post: 04-29-2007, 08:03 PM
