585,927 active members*
3,431 visitors online*
IndustryArena Forum > Material Technology > Glass, Plastic and Stone > Machining High Density Polyethylene (HDPE)
    Oct 2006
    158
    I have to cut 3/4" HDPE and 1/2" HDPE. My machine and tool specifications are as follows:
    The Bit:
    - CMT Brand
    - 1/4" Diameter
    - 1/4" Shank
    - 1" Cut Depth
    - 2-1/2" Length
    - 2 Flute
    Router:
    - Porter and Cable Brand
    - Electronic five-speed: 10,000; 13,000; 16,000; 19,000; 21,000 RPM
    What feedrate (IPM), spindle speed (RPM), and depth of cut should I make per pass?
    Dec 2007
    32
    go fast
    I have cut a lot of HDPE my mills only have 10000 rpm but if I had more rpm i could go faster I can run 175 ipm with 10000 rpm I would recomend start there and work up more rpm then ipm just keep an eye on the chip if it gets to thick go more rpm you can push it pretty hard its a fun mat. to work with ps keep sharp tools handy
    you never know what you can do, until you have to undo something you have done!
    Jan 2008
    35
    machine as fast rpm and ipm as you can until the material starts to melt and then back r down on the rpm. it cuts really nice unles your running it on a lathe, then it winds up on everything because you just cant push it hard enough to break the chip.
    Sep 2019
    I am recently shifted in Oregon and I need HDPE Tubing, do you have any reference of any local distributor? Previously I was living in Michigan and used to order my HDPE Tubing from: https://www.spiratex.com Thanks!!
  1. Where to buy high density foam?
    By WarrenW in forum Material Machining Solutions
    Last Post: 03-08-2013, 04:04 PM
  2. High Density Urethane Foam (A.K.A. Butter-board)
    By rigo430 in forum Material Machining Solutions
    Last Post: 09-10-2010, 07:06 PM
  3. Replies: 8
    Last Post: 10-01-2007, 09:40 PM
  4. cutting data for Delrin and High Molecular Weight Polyethylene
    By jedioliver in forum Glass, Plastic and Stone
    Last Post: 11-14-2006, 02:23 PM
  5. high-density polyethylene
    By MBG in forum MetalWork Discussion
    Last Post: 09-13-2005, 01:31 PM
