585,992 active members*
5,178 visitors online*
IndustryArena Forum > CAM Software > Mastercam > copying surface roughing operations
    Aug 2005
    149
    Hey guys,
    I was wondering if there us a way to use the same surfaces and boundries with out having to re-pick them...I'm using a surface rough pocket on one operation and I want to do a finish parallel path on the same surface....is there a way to do this with out reselecting the surfaces and boundries?
    V9
    Thanks.
    Mar 2006
    1013
    Create your finish toolpath and grab any surfaces. After it's done processing, grab the geometry from the surface rough operation, hold down the mouse while you drag it down to the Finish operations geometry, Drop it & regenerate.
    Mike Mattera
    Tips For Manufacturing Training CD's, DVD's for Mastercam, SolidWorks, Inventor, G-Code Training & More
    http://www.tipsforcadcam.com
  1. Dongle copying
    By JR1050 in forum Uncategorised CAM Discussion
    Last Post: 12-27-2007, 06:32 PM
  2. Toolpath operation copying
    By JWWalthall in forum Mastercam
    Last Post: 05-05-2007, 04:06 AM
  3. Replies: 10
    Last Post: 11-20-2006, 10:49 PM
  4. AutoCAD offsets and copying
    By skippy in forum Autodesk
    Last Post: 05-19-2005, 07:12 PM
  5. copying in Autocad
    Last Post: 04-11-2005, 02:55 PM
