Here is what I am trying to do… On a rough facing canned cycle, I am trying to slow down the feed rate half way down the face of the part. I was using two separate line segments to create the profile of the face. On the second line, I inserted a feed rate instead of leaving it blank and letting it assume the inserted feed rate in the tool change. When the canned cycle executes, the roughing segments of the pattern stay at the feedrate set in the tool change throughout the entire cycle, but the finishing part (final cut) of the roughing pattern executes at the feedrate set in the tool change except where I change the feed rate in the line segments.
Here is my question… How do I get the roughing segment to use the lower feedrate in the roughing pattern when I have defined it like it does in the finishing segment of the roughing canned cycle?
I am a new Mitronics user… so any help would be greatly appreciated!
