NO DON'T PUT IT THERE!
Put the negative with one of the other blue ones, and the positive with one of the other red/orange ones.
Ther are THREE output negatives and three output positives.
Your fourth axis has to paralleled with either the X,Y or Z power.
You connected to the current sense connections, and blew up the current sense resistors. That's why they are marked S+ and S-.
Do not connect to S+ and S-.
On the stepper driver turn the adjustment fully clockwise before applying power.
Follow the super Driver Manual page 6 to adjust the current.
If in doubt ask more questions.
When you move th axis, if it is acting like it is starving for power, ie missing stepps or growling, increase the current by turning the adjustment slowly CCW.
Make sure your motor tuning setup is roughly similar to the X or Y axis setup.
I installed mine yesterday. Switch 3 down, the rest up.
Motor tuning first entry 1000, then 1200, then 1200 should work.
Don't forget to hit SAVE before you exit the screen.
Eventually my second box reads 2000.
Can't remember name of boxes.
If you are using 25KHZ then these settings will differ.
I am using 45KHZ.
