ok i just bought a kit from keling i did the setup and rechek it on the phone with the guy from keling and he says that all is hooked up properly and that my trouble is with mach3 and the pc
so here goes
pc spec
athlonxp 2400+
asus a7n8x rev1.04
1gig ddr 333
40gig hdd
radeon 9800pro 128mb
winxp pro sp2 with all current update
mach3 the latest trial
cnc component are
1x 48v/7.3a psu
3x kl6050 driver
2x 495oz 4leads motor
1x 640oz 8leads motor
1x c10 bob
as for the 5v required for the c10 its connected straight to the computer 5v line wich read as 4.95v on the multimeter
currently i have only one motor hooked up and the shaft lock when i turn on the setup
now port&pin are set for the x axis to step2, dir3 as for step and dir active low is enabled, port for step and dir is set to one and i have enabled e stop as it says in the info and vid tutorial
now here is my problem the motor wont move
i currently have my lpt addy set to 378 but strangly enough when i go in the resource tab of my lpt port i have two addy there one is 378 the other is 778 but my mobo only as one lpt port the guy from keling think my problem might be there what do you think and does anybody have or had a similar problem
edit: forgot to add in the bios the lpt port is set to ecp/epp 378/irq7
The opinions expressed in this post are my own. -Les opinions exprimé dans ce messages sont les mienne
yeah i have check my setup a second time on the phone with the guy from keling and it is finally not a problem between mach and the lpt its my c10 board he sent me that as a bug
Just buy the C1G board it will save you a lot of head ache cuz it has LED's on inputs and outs, and you see if a switch is working or not with out even connecting it to a lpt port: http://www.cnc4pc.com/Store/osc/prod...products_id=49
well the thing is i got it with my package from kelling and anyway my replacement is allready on its way arturo sent it today and my next upgrade will come as a c11
We use cookies to optimize our website for you and to be able to improve it continuously. By clicking the "Accept" button, you expressly agree to the use of cookies. For further information on cookies, please refer to our privacy policy.
