585,969 active members*
4,610 visitors online*
    Nov 2005
    244
    zigzag toolpath
    Is there a way in Mastercam 9 to have the first cut feedrate different from the main feedrate? The same question pertaining to the traverse cut feedrate to the main feedrate.
    To do this manually is to time consuming.
    Thank You
    what are you cutting ? mill, lathe 2-d? 3-d?
    Steve
    www.cad2cam.net
    www.cad2cam.net
    Programmer/ Certified Cam Instructor
    Nov 2005
    244
    zigzag toolpath
    I was just refering to the 2d pocketing and the 3d pocketing. I like a zigzag pattern for roughing. But the feedrate needs to be slower on the first cut and on the traverse cut.
    I have seen cam systems with this option. I was hoping Mastercam had it and I just did not know where to find it or if there was a easy work around.
    Thank You
    Ramp entry allows you to use a plunge rate or feed rate but as far as changing the travers cut, right click on the pocket in the op manager and go to toolpath editor atthe bottom of the list, this will allow you to change feed and speed from point to point.
    Steve
    www.cad2cam.net
    www.cad2cam.net
  1. Help with toolpath.
    By MagooT in forum Mastercam
    Last Post: 02-20-2010, 02:04 AM
  2. Toolpath Spaces
    By Oldbill in forum Uncategorised CAM Discussion
    Last Post: 01-21-2008, 04:21 PM
  3. toolpath suggestion
    By alan2k7 in forum BobCad-Cam
    Last Post: 07-08-2007, 09:31 PM
  4. Toolpath set up?
    By Jessica in forum ArtCam Pro
    Last Post: 03-13-2007, 05:13 PM
  5. 3D toolpath help
    By Dfennell in forum BobCad-Cam
    Last Post: 02-03-2007, 08:13 AM
