I have used the "Contour Toolpath", "Rotation Axis", "Axis Substitution" and "Substitute Y axis" for machining before, there is no problem.
Now because the work piece's diameter is too big, I therefore must face the work piece axle center to Z axis and uses aggerate head to let the cutting tool's direction as right side view for machining, but there is a problem that the axis substitution has not substituted for the Z axis. Is there any solution for this problem?
