586,005 active members*
5,181 visitors online*
    Dec 2007
    15
    wiring power supply
    i have a 5axis controller with 5 seperate driver boards.
    I need to send power to each of the boards seperately, could anyone tell me if i should connect all of these wires together to the connection on the power supply, or is there some kind of splitter i can use to connect the 5 sets of wires to the power supply?
    If so please let me know where i can find such a splitter.
    thanks
    rick
    24221
    They all should be connected at the power supply output termination, If the power supply connection is rather small to take all 5 wires, there is not alot commercially available without using say two 5 terminal blocks and making all 5 common on the top end of each 5 terminal strip, which leaves 5 bottom terminals for your drives.
    Al.
    Albert E.
    Apr 2014
    Re: wiring power supply
    hi i have one power suppy of 40 w for tube 40w co2
    and it have 2 conector with letter k+ and k- and other conector with letter d+ and d- you can help
    for understand this meaning of this letter in conector thanks
  1. Wiring vfd and power supply. 30 amp enough?
    By alan_3301 in forum Phase Converters
    Last Post: 02-17-2012, 05:21 PM
  2. Wiring and Power Supply Help Please
    By ashjam in forum CNC Machine Related Electronics
    Last Post: 08-14-2010, 08:38 PM
  3. need help wiring power supply
    By timewarp in forum Automation Technology Products
    Last Post: 06-21-2010, 03:25 AM
  4. help wiring a power supply please..
    By justin2 in forum CNC Machine Related Electronics
    Last Post: 12-19-2008, 04:33 PM
  5. AC Wiring to Power Supply
    By blue_steel in forum CNC Machine Related Electronics
    Last Post: 12-02-2008, 04:51 AM
