Using 2 of the following spec transformer: DUAL INPUT VOLTAGE OF 110 VAC, OR 220 VAC 3 AMPS. OUTPUT 27 VOLTS @ 12 AMPS. TOTAL VOLT-AMP RATING 335.
It's not that I am planning on using this particular transformer. I am posting the pic & specs to use for discussion purposes.
Imput voltage isn't an issue for me to wire, pretty much straight forward there.
It's the output(s) that it all becomes foggy.
If the outputs are wired parallel. Am I correct in assuming you still have 27V, but wattage & amperage doubles to 24A, 670W?
Now what happens if wired series? Do you get 54V, 12A, ?W. ???
