585,981 active members*
4,288 visitors online*
    Mar 2006
    8
    Connecting DRO to parallel port
    Hi all,
    I have the easson DRO system. I would like to use the encoders outputs as an inputs to my PC's parallel port.
    I couldn't find any document that describes the DB-9 connectors pinout or any other informatiom about electrical compatibility (all I know that it is a TTL compatible).
    Does anyone here have a pinout diagram?
    Do I need to add an electrical convertor?
    Thanks in advance,
    Zvika
    24221
    If you look at the www.Lindsayengraving.com version, it shows transistor buffers, I have experimented with the TTL line driver encoders and scales, direct in to the port, seems to work better.
    Note the other site link and the modern choices of Parallel port modes under Windows.
    If buffers are needed, I prefer the 2N7000 Fet.
    BTW DB9 is usually serial RS232?
    Al.
    Albert E.
  1. Connecting Arc Welders in parallel?
    By Paragon36 in forum Uncategorised MetalWorking Machines
    Last Post: 11-17-2007, 02:08 AM
  2. Connecting 2 steppers in parallel
    By salvaCNC in forum CNC Wire Foam Cutter Machines
    Last Post: 09-29-2007, 12:42 AM
  3. connecting a printer to a Mazak with serial port
    By z-zero in forum DNC Problems and Solutions
    Last Post: 09-08-2007, 01:41 AM
  4. Second parallel port?
    By essa in forum LinuxCNC (formerly EMC2)
    Last Post: 04-12-2006, 08:18 AM
  5. Parallel port
    By Aldoseri in forum BobCad-Cam
    Last Post: 03-13-2006, 05:10 PM
