585,992 active members*
5,533 visitors online*
Results 1 to 15 of 15
    Jan 2008
    7
    mitsubishi meldos 310 - dnc problem
    any body help me with mitsubishi meldas 310 mill
    when i transfer a program (this program creat by power mill & send to the machine by cimco edit ) to the memory & execute this program from memory i dont have any problem & the xyz axis run very good &smooth & countiuse but when i want to run this program from pc by direct connection (dnc mode) yhe xyz axis dont run smooth & i have a step-by-step move (like this -----) two program are same and all setting in cnc are also same
    2932
    What baud rate are you communicating at? What feedrate are you programming? How long are the line segments you are interpolating? Sounds like the baud rate is too low for the feedrate you have programmed.
    Jan 2008
    7
    buadrate
    feedrate is 2000mm)min and baudrate is 9600 but in meldos catalog say the max baudrate is 1240
    2932
    I'm not familiar with the Meldas 310, but I'm pretty sure there is no such baud rate. 110,300,600,1200,2400,4800,9600 are all pretty standard, but 1240?
    I'm also not familiar with Cimco Edit's DNC settings, but check to see if there's either "Character Send Delay", or "Line Send Delay" or anything like that that could be slowing the transmission down.
    Jan 2008
    7
    dnc
    sory for this typing ignore . 1200 is true . and i can find these parameters in cimco :
    delay befor each line
    handshake timeout
    breack after receiving character
    are these useful for our problem ? and do you have any good suggest for adjust this parameter ?
    do you have any good software for dnc ?
    and say again tanke you for your help
    Jan 2008
    7
    dnc
    handshake timeout
    Jan 2008
    7
    handshake timeout
    2932
    Delay Before Each Line sounds like the one. If it's not already, try setting that to 0.
    I'm confused... is your baud rate set to 1200 or 9600? If it's 1200, bump it up to 4800 or 9600. If it's 9600, bump it up to 19200. If your cable is good, and the handshaking is working properly, you shouldn't get overflows.
    Feb 2007
    498
    the 310 wont handle a rate higher than 9600,what is your computer?older one,sometimes this causes a dnc problem
    Jan 2008
    7
    dnc
    i have a same problem in richmond machine , in richmond my baudrate is 9600 & in meldos machine 1200 , and i use new labtop for dnc
    Sep 2007
    122
    handshake timeout
    Go to your Parameters - in/out screen and see what the handshake time out setting is. I know Mitsubishi lets you set this. Bump it up to 200 seconds to see if this helps. check out www.meau.com
    :rainfro:
    Sep 2007
    122
    My problem also.
    I am also looking for a good up-load/download program. I can not communicate with the Mitsubishi Meldas L3. I have gotten a few characters using some stuff but nothing usefull,
    2932
    mostafabagheri,
    I checked the Cimco Edit V5 documentation, and the only thing I see that could slow the transmission is the Delay Before Each Line. Did you check to see if that's set that to 0 yet?
    Jul 2005
    409
    Mitsubishi up/download
    Hutch o7,
    I recently aquired 2 Machning centers with Mitsu MO controls. I use Hyperterm in windows for sending/receiving files. I am running that at 19.2 and with a 50 msec. line delay, it feeds faster error free than at 9600 with no line delay.
    I messed around for a while trying different settings until I got it right. If you are still having trouble let me know and I will send you the settings I use.
    Cutmore
    Jan 2019
    Better you can use micro dnc unit for transferring the program, that will save the space and accurate data transfer
  1. Dnc problem for Mitsubishi Meldas 520AM
    By koeitool in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 11-11-2022, 07:12 AM
  2. Mitsubishi spindle problem
    By wcopley in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 09-03-2013, 08:58 PM
  3. Dnc problem for Mitsubishi Meldas 520AM
    By koeitool in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 05-04-2010, 06:40 PM
  4. Mitsubishi DWC-110H A Wire EDM Floppy Problem
    By tjurek in forum DNC Problems and Solutions
    Last Post: 10-11-2007, 01:08 PM
  5. HELP! Mitsubishi cnc hobb problem
    By Jay Rad in forum Uncategorised MetalWorking Machines
    Last Post: 03-22-2007, 07:08 AM
