When I turn on the control the CRT reads system error 402. I can not change to any other screens i do not think it is on the alarm screen. Was running find when I shut it off.
There is no alarm 402 that I can find on the 6M. Could that be alarm 602 or 902 ?
It is a "system error" 402
Found it. The 402 alarm is a 4th axis overload alarm. Do you have a 4th axis? If not, then the option parameter for the 4th axis somehow got turned on, so now it's sensing an overload for a servo that's not there.
If you have a 4th axis, push the little RESET button on the back of the servo. Also, check the 4th axis cables to see that they're all connected properly.
It is wired for a 4th axis but I have never use the 4th axis.
It is wired for a 4th axis but I have never used the 4th axis.
