Originally Posted by
CoAMarcus
What we are using is JB-Weld. This is an easy mixing epoxy, strong as anything you can find, cures at 150F, and is good up to 600F. Just put a spot on the board, stick the MOSFET down on it, run it through the oven at 150F, and you are good to go. Make sure the leads aren't sticking above the panel and you can just stencil it like normal.
As I type this the machines are being set up to run the G250s. We get the stencil tomorrow, and if everything looks good we will run limited production some time very soon. As promised, there will be lots of pictures. ;-)
-Marcus Freimanis
Hi Marcus,
My question was to do with the paste stencils used. How do you determine the apertures size for the THC? The apertures need to be large enough to apply enough pate to fill the hole space wit solder. I don't know how to determine this other than trial and error.
Cheers,
Peter.
Homann Designs - http://www.homanndesigns.com/store
