Im building a X2 size Mini Mill using a X&Y ENCO Table "Like CNCfun&games is using in his POST". The X&Y screws are 10TPI.
And the Z axis will be the same 10 TPI. Will be using Ball Bearings on all screw Axis.
Want it to be able to have the power to cut with a max 1/2" end mill & 2-3" Fly cutter on Steel.
I want steady movement & holding power from the stepper motors.
OK! With that said I would like to know what "OZ" 23 size stepper motors I should get to do the job? I was thinking 285 OZ.
But may be I need 300-400 OZ stepper motors? Since im milling Steel?
