585,977 active members*
4,138 visitors online*
Results 1 to 19 of 19
    Dec 2007
    4
    hitachi seiki vm40 seikos m2
    I need some help .my maschine stops in the PC NOT READY how can I enter the parameters in RAM .I probebly lost the RAM data when the batery was changed.
    Pleace halp if someone knows how .
    Reagard
    Boštjan
    Feb 2008
    VM40
    Hi Bostjan
    I have just replace a PC PCB on a seicos control.
    -You should check to see if all data pc data is set correctly ie slbus/ table etc.
    -Check to see if the ladder is still on the pc pcb.
    - Make sure the write enable switch is not on.
    adt
    Sep 2008
    138
    Need help with Hitachi Seiki VM40
    Dear all
    I have Hitachi Seicos VM40 with controller is Micron 16 MII. Battery was dead so all data was lost. Dose anybody have all data for my machine. I'm willing to buy it
    Regards
    Aug 2007
    138
    VK45 parameters
    greenery_fr;
    I have a VK45 and a manual for the VM40 that I use as my bible to the VK45. The machines are nearly identical and the VM40 manual has much more readable information than the VK45 manual. I suspect most of the parameters are the same too. Here is a list of mine:
    N0P00010110
    N1P00000000
    N2P01101000
    N3P00100010
    N4P11000000
    N5P01011000
    N6P01001000
    N7P00010000
    N8P00100000
    N9P00010000
    N10P00000011
    N11P00000000
    N12P00101010
    N13P00000000
    N14P00000000
    N15P00100001
    N16P00100000
    N17P01010000
    N18P01010100
    N19P00000000
    N20P30
    N21P30
    N22P30
    N23P0
    N24P4
    N25P4
    N26P3
    N27P0
    N28P200
    N29P200
    N30P200
    N31P0
    N32P500
    N33P300
    N34P30
    N35P0
    N36P0
    N37P50
    N38P500
    N39P300
    N40P15000
    N41P15000
    N42P15000
    N43P2160
    N44P6000
    N45P6000
    N46P1118
    N47P1118
    N48P6000
    N49P40
    N50P300
    N51P0
    N52P0
    N53P0
    N54P0
    N55P0
    N56P1
    N57P0
    N58P0
    N59P50
    N60P508200
    N61P-508200
    N62P3380
    N63P-457400
    N64P200
    N65P-457400
    N66P361000
    N67P-361000
    N68P0
    N69P0
    N70P0
    N71P0
    N72P0
    N73P0
    N74P0
    N75P0
    N76P-508000
    N77P3180
    N78P-368
    N79P0
    N80P0
    N81P0
    N82P0
    N83P0
    N84P0
    N85P0
    N86P0
    N87P0
    N88P-142
    N89P1645
    N90P300
    N91P0
    N92P-198829
    N93P0
    N94P14444
    N95P1250
    N96P4
    N97P2
    N98P-737
    N99P0
    N100P197
    N101P1181
    N102P-130000
    N103P-20000
    N104P0
    N105P0
    N106P0
    N107P79
    N108P79
    N109P79
    N110P79
    N111P79
    N112P0
    N113P394
    N114P394
    N115P0
    N116P0
    N117P0
    N118P9999999
    N119P-9999999
    N120P0
    N121P0
    N122P0
    N123P0
    N124P0
    N125P0
    N126P0
    N127P0
    N128P0
    N129P0
    N130P0
    N131P-508000
    N132P0
    N133P0
    N134P570000
    N135P100000
    N136P100000
    N137P0
    N138P0
    N139P0
    N140P30
    N141P5
    N142P0
    N143P0
    N144P0
    N145P0
    N146P0
    N147P0
    N148P0
    N149P0
    N150P0
    N151P0
    N152P0
    N153P0
    N154P0
    N155P0
    N156P0
    N157P0
    N158P0
    N159P0
    N160P5000
    N161P3000
    N162P0
    N163P0
    N164P0
    N165P0
    N166P0
    N167P0
    N168P0
    N169P0
    N170P10000
    N171P10000
    N172P10000
    N173P0
    N174P0
    N175P4000
    N176P0
    N177P0
    N178P0
    N179P0
    N180P0
    N181P0
    N182P0
    N183P0
    N184P0
    N185P0
    N186P45
    N187P46
    N188P0
    N189P0
    N190P0
    N191P0
    N192P0
    N193P0
    N194P0
    N195P0
    N300P00000000
    N301P00000000
    N302P00000000
    N303P00000000
    N304P00000000
    N305P00011000
    N306P00000000
    N307P00000000
    N308P00000000
    N309P00000000
    N310P00000000
    N311P00000000
    N312P00000000
    N313P00000000
    N314P00000000
    N315P00000000
    N316P00000000
    N317P10010000
    N318P00000101
    N319P00000000
    N320P0
    N321P0
    N322P0
    N323P0
    N324P0
    N325P0
    N326P0
    N327P0
    N328P0
    N329P0
    N330P0
    N331P0
    N332P0
    N333P0
    N334P0
    N335P0
    N336P0
    N337P0
    N338P0
    N339P0
    N340P0
    N341P0
    N342P0
    N343P0
    N344P0
    N345P0
    N346P0
    N347P0
    N348P0
    N349P0
    N350P0
    N351P0
    N352P0
    N353P0
    N354P0
    N355P0
    N356P0
    N357P0
    N358P0
    N359P0
    N1000P2050
    N1001P3045
    N1002P4045
    N1003P0
    N1004P0
    N1100P10
    N1101P10
    N1102P10
    N1103P0
    N1104P0
    N2000P0
    N2001P0
    N2002P0
    N2003P0
    N2004P0
    N2005P0
    N2006P0
    N2007P1
    N2008P0
    N2009P1
    N2010P0
    N2011P1
    N2012P0
    N2013P0
    N2014P0
    N2015P1
    N2016P0
    N2017P0
    N2018P0
    N2019P1
    N2020P0
    N2021P0
    N2022P0
    N2023P1
    N2024P0
    N2025P0
    N2026P0
    N2027P1
    N2028P0
    N2029P0
    N2030P0
    N2031P1
    N2032P0
    N2033P0
    N2034P0
    N2035P1
    N2036P0
    N2037P0
    N2038P0
    N2039P1
    N2040P0
    N2041P0
    N2042P0
    N2043P0
    N2044P0
    N2045P0
    N2046P0
    N2047P0
    N2048P0
    N2049P0
    N2050P0
    N2051P0
    N2052P0
    N2053P0
    N2054P0
    N2055P0
    N2056P0
    N2057P0
    N2058P0
    N2059P1
    N2060P0
    N2061P0
    N2062P0
    N2063P0
    N2064P0
    N2065P0
    N2066P0
    N2067P0
    N2068P0
    N2069P0
    N2070P0
    N2071P0
    N2072P0
    N2073P0
    N2074P0
    N2075P0
    N2076P0
    N2077P0
    N2078P0
    N2079P1
    N2080P0
    N2081P0
    N2082P0
    N2083P0
    N2084P0
    N2085P0
    N2086P0
    N2087P0
    N2088P0
    N2089P0
    N2090P0
    N2091P0
    N2092P0
    N2093P0
    N2094P0
    N2095P0
    N2096P0
    N2097P0
    N2098P0
    N2099P0
    N2100P0
    N2101P0
    N2102P0
    N2103P0
    N2104P0
    N2105P0
    N2106P0
    N2107P0
    N2108P0
    N2109P0
    N2110P0
    N2111P0
    N2112P0
    N2113P0
    N2114P0
    N2115P0
    N2116P0
    N2117P0
    N2118P0
    N2119P0
    N2120P0
    N2121P0
    N2122P0
    N2123P0
    N2124P0
    N2125P0
    N2126P0
    N2127P0
    N2128P0
    N2129P0
    N2130P0
    N2131P0
    N2132P0
    N2133P0
    N2134P0
    N2135P0
    N2136P0
    N2137P0
    N2138P0
    N2139P0
    N2140P0
    N2141P0
    N2142P0
    N2143P0
    N2144P0
    N2145P0
    N2146P0
    N2147P0
    N2148P0
    N2149P0
    N3000P0
    N3001P0
    N3002P0
    N3003P0
    N3004P0
    N3005P0
    N3006P0
    N3007P0
    N3008P0
    N3009P0
    N3010P0
    N3011P0
    N3012P0
    N3013P0
    N3014P0
    N3015P0
    N3016P0
    N3017P0
    N3018P0
    N3019P0
    N3020P0
    N3021P0
    N3022P0
    N3023P0
    N3024P0
    N3025P0
    N3026P0
    N3027P0
    N3028P0
    N3029P0
    N3030P0
    N3031P0
    N3032P0
    N3033P0
    N3034P0
    N3035P0
    N3036P0
    N3037P0
    N3038P0
    N3039P0
    N3040P0
    N3041P0
    N3042P0
    N3043P0
    N3044P0
    N3045P0
    N3046P0
    N3047P0
    N3048P0
    N3049P0
    N3050P0
    N3051P0
    N3052P0
    N3053P0
    N3054P0
    N3055P0
    N3056P0
    N3057P0
    N3058P0
    N3059P0
    N3060P0
    N3061P0
    N3062P0
    N3063P0
    N3064P0
    N3065P0
    N3066P0
    N3067P0
    N3068P0
    N3069P0
    N3070P0
    N3071P0
    N3072P0
    N3073P0
    N3074P0
    N3075P0
    N3076P0
    N3077P0
    N3078P0
    N3079P0
    N3080P0
    N3081P0
    N3082P0
    N3083P0
    N3084P0
    N3085P0
    N3086P0
    N3087P0
    N3088P0
    N3089P0
    N3090P0
    N3091P0
    N3092P0
    N3093P0
    N3094P0
    N3095P0
    N3096P0
    N3097P0
    N3098P0
    N3099P0
    N3100P0
    N3101P0
    N3102P0
    N3103P0
    N3104P0
    N3105P0
    N3106P0
    N3107P0
    N3108P0
    N3109P0
    N3110P0
    N3111P0
    N3112P0
    N3113P0
    N3114P0
    N3115P0
    N3116P0
    N3117P0
    N3118P0
    N3119P0
    N3120P0
    N3121P0
    N3122P0
    N3123P0
    N3124P0
    N3125P0
    N3126P0
    N3127P0
    N3128P0
    N3129P0
    N3130P0
    N3131P0
    N3132P0
    N3133P0
    N3134P0
    N3135P0
    N3136P0
    N3137P0
    N3138P0
    N3139P0
    N3140P0
    N3141P0
    N3142P0
    N3143P0
    N3144P0
    N3145P0
    N3146P0
    N3147P0
    N3148P0
    N3149P0
    N4000P0
    N4001P2
    N4002P0
    N4003P0
    N4004P2
    N4005P0
    N4006P0
    N4007P2
    N4008P0
    N4009P0
    N4010P2
    N4011P0
    N4012P2
    N4013P0
    N4014P0
    N4015P2
    N4016P0
    N4017P0
    N4018P0
    N4019P2
    N4020P0
    N4021P0
    N4022P1
    N4023P0
    N4024P2
    N4025P0
    N4026P2
    N4027P0
    N4028P0
    N4029P2
    N4030P0
    N4031P0
    N4032P1
    N4033P0
    N4034P2
    N4035P0
    N4036P2
    N4037P0
    N4038P2
    N4039P0
    N4040P0
    N4041P2
    N4042P0
    N4043P1
    N4044P0
    N4045P0
    N4046P0
    N4047P0
    N4048P0
    N4049P0
    N4050P0
    N4051P0
    N4052P0
    N4053P0
    N4054P0
    N4055P0
    N4056P0
    N4057P0
    N4058P0
    N4059P0
    N4060P0
    N4061P0
    N4062P0
    N4063P0
    N4064P0
    N4065P0
    N4066P0
    N4067P0
    N4068P0
    N4069P0
    N4070P0
    N4071P0
    N4072P0
    N4073P0
    N4074P0
    N4075P0
    N4076P0
    N4077P0
    N4078P0
    N4079P0
    N4080P0
    N4081P0
    N4082P0
    N4083P0
    N4084P0
    N4085P0
    N4086P0
    N4087P0
    N4088P0
    N4089P0
    N4090P0
    N4091P0
    N4092P0
    N4093P0
    N4094P0
    N4095P0
    N4096P0
    N4097P0
    N4098P0
    N4099P0
    N4100P0
    N4101P0
    N4102P0
    N4103P0
    N4104P0
    N4105P0
    N4106P0
    N4107P0
    N4108P0
    N4109P0
    N4110P0
    N4111P0
    N4112P0
    N4113P0
    N4114P0
    N4115P0
    N4116P0
    N4117P0
    N4118P0
    N4119P0
    N4120P0
    N4121P0
    N4122P0
    N4123P0
    N4124P0
    N4125P0
    N4126P0
    N4127P0
    N4128P0
    N4129P0
    N4130P0
    N4131P0
    N4132P0
    N4133P0
    N4134P0
    N4135P0
    N4136P0
    N4137P0
    N4138P0
    N4139P0
    N4140P0
    N4141P0
    N4142P0
    N4143P0
    N4144P0
    N4145P0
    N4146P0
    N4147P0
    N4148P0
    N4149P0
    N5000P0
    N5001P0
    N5002P0
    N5003P0
    N5004P0
    N5005P0
    N5006P0
    N5007P0
    N5008P0
    N5009P0
    N5010P0
    N5011P0
    N5012P0
    N5013P0
    N5014P0
    N5015P0
    N5016P0
    N5017P0
    N5018P0
    N5019P0
    N5020P0
    N5021P0
    N5022P0
    N5023P0
    N5024P0
    N5025P0
    N5026P0
    N5027P0
    N5028P0
    N5029P0
    N5030P0
    N5031P0
    N5032P0
    N5033P0
    N5034P0
    N5035P0
    N5036P0
    N5037P0
    N5038P0
    N5039P0
    N5040P0
    N5041P0
    N5042P0
    N5043P0
    N5044P0
    N5045P0
    N5046P0
    N5047P0
    N5048P0
    N5049P0
    N5050P0
    N5051P0
    N5052P0
    N5053P0
    N5054P0
    N5055P0
    N5056P0
    N5057P0
    N5058P0
    N5059P0
    N5060P0
    N5061P0
    N5062P0
    N5063P0
    N5064P0
    N5065P0
    N5066P0
    N5067P0
    N5068P0
    N5069P0
    N5070P0
    N5071P0
    N5072P0
    N5073P0
    N5074P0
    N5075P0
    N5076P0
    N5077P0
    N5078P0
    N5079P0
    N5080P0
    N5081P0
    N5082P0
    N5083P0
    N5084P0
    N5085P0
    N5086P0
    N5087P0
    N5088P0
    N5089P0
    N5090P0
    N5091P0
    N5092P0
    N5093P0
    N5094P0
    N5095P0
    N5096P0
    N5097P0
    N5098P0
    N5099P0
    N5100P0
    N5101P0
    N5102P0
    N5103P0
    N5104P0
    N5105P0
    N5106P0
    N5107P0
    N5108P0
    N5109P0
    N5110P0
    N5111P0
    N5112P0
    N5113P0
    N5114P0
    N5115P0
    N5116P0
    N5117P0
    N5118P0
    N5119P0
    N5120P0
    N5121P0
    N5122P0
    N5123P0
    N5124P0
    N5125P0
    N5126P0
    N5127P0
    N5128P0
    N5129P0
    N5130P0
    N5131P0
    N5132P0
    N5133P0
    N5134P0
    N5135P0
    N5136P0
    N5137P0
    N5138P0
    N5139P0
    N5140P0
    N5141P0
    N5142P0
    N5143P0
    N5144P0
    N5145P0
    N5146P0
    N5147P0
    N5148P0
    N5149P0
    N6000P0
    N6001P100
    N6002P520
    N6003P1000
    N6004P2000
    N6005P3700
    N6006P7200
    N6007P10000
    N6008P20000
    N6009P37000
    N6010P50000
    N6011P0
    N6012P0
    N6013P0
    N6014P0
    N6015P0
    N6016P0
    N6017P0
    N6018P0
    N6019P0
    N6020P0
    N6021P0
    N6022P0
    N6023P0
    N6024P0
    N6025P100
    N6026P25
    N6027P1
    N6028P0
    Jun 2008
    17
    Seikos MII in VM40
    Hi, I need some of help with a Hitachi seiki Machine the model is VM-40 and it has Seikos Control MII, the languaje are change to chinesse or something like that, but I don't know how to restart or change the idiom. can somebody help me please???
    Re: VK45 parameters
    do you have the procedure for loading the parameter manually??
    sting
    Apr 2011
    112
    Re: hitachi seiki vm40 seikos m2
    Helllo guys i just got a Seiki Seicos my2 and i have some smalll problems . My machine had 5 axis some time ago . Some one stole the 4x5 axis from the machine and cut the wire . I have managed to get the wires out . started the machine and i need some how to get out the 4x5 axis from the software so i can work with the machine in 3 axis as i want . Did some one have made this modification ?
    AlexClick image for larger version.
ID:	343302Click image for larger version.
    Aug 2007
    138
    Quote Originally Posted by aventtini888 View Post
    Alex,
    Looks like you have more pressing problems with the X axis. Is the table hard against one end or froze up?
    Apr 2011
    112
    it was on a hard limit and i slove it .
    Apr 2011
    112
    If i dont have the 4x5 axis , drivers can still have the FG missing 24v so it dont want to enable .
    Aug 2007
    138
    It may take a couple of days but I will see if I can fine the parameters to disable 4 & 5
    Apr 2011
    112
    i dont have the manuals they are missing but i have found some manuals online . I can seem to have the same seicos menius and error list . Some of them missing
    Dec 2009
    539
    Can you confirm the control? Is this a VM40 or a VM40II (looks to be a VM40II to me)
    Seicos MYII is not the same as Seicos II - I can give you the parameters you need if you can confirm your control. Take a pic of the control cabinet or the software page and I will help you out.
    Apr 2011
    112
    Its MyII , i will make some pics on monday . Its funny that on the machine page the absolut positon is x0.000 y0.000 z0.000 i think it needs the encoder reset position done . This is my first time on a seicos control and it looks to be a complicated machine .
    Apr 2011
    112
ID:	343596Click image for larger version.
ID:	343598 here are some pics let me know if you need someting specific.
    Oct 2018
    hi...how did you solve that problem?....ls answer me...i have a seiki whit seicos my II controller...and i have a user's msg "240 X axis interlock alarm"...i've manualy moved the x axis by removing the cover and manualy scruig it out of limit switch...the OT alarm gone but still can't erase this ms and it wa't let me start the servo...so, i can't move on any axes...pls reply
    Oct 2018
    Quote Originally Posted by shas595 View Post
    hi....can you help me plese...i have a hitachi seiki seicos my 2 ....i have a user msg : "240 x axis interlock alarm" and i can't erase it even after i ballscrwed the x axis out of athe limit sitch...haw can i erase that msg, because it wan't let me start up my servo motor
    Oct 2018
    Dec 2009
    539
    Send me a PM with your email and Ill see if I can help
    John
  1. Hitachi Seiki VM40 seicos 2
    By bevins in forum Hitachi Seikis
    Last Post: 05-08-2013, 04:06 AM
  2. Hitachi seiki seikos III
    By jam-man in forum Controller & Computer Solutions
    Last Post: 02-23-2013, 02:52 PM
  3. Hitachi Seiki Seikos III Help
    By Andy177 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-24-2010, 05:46 AM
  4. hitachi seiki vm40 error 141
    By Mousie in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-15-2009, 10:10 AM
