585,555 active members*
3,162 visitors online*
Thread: Student
    Jan 2008
    6
    Question Student
    Hi!, I'm a student just learning begining CNC lathe programming and I am having a certain amount of trouble. The problem is that I have been given two lines of code :N250 G01 X.875 Z-.518 F.012 and N260 X1.025 Z-.593. We are are being taught to calculate corner breaks long hand without using G42/G41. I am asked to deduce from these lines of code the angle (per side) of the taper being machined. The tnr is .031. I am also given the selection of 30, 25, 45, or 63 degrees. Can anyone show me how this is done?? If this is the wrong forum for this type of question, please forgive me and kindly forward me to the proper one. Thanks.
    Jan 2007
    355
    The slope (or angle) of the toolpath is independent of the tool nose radius.
    The nose radius will effect the size of a chamfer or corner break.
    Anyway, to calculate the angle:
    angle = arctangent(rise / run)
    = arctangent (change in X / change in Z)
    = arctangent( ((1.025 - .875)/2) / (-.593 - -.518) )
    x is diameter value, divide by 2 for radial distance
    = arctangent (-1)
    = -45 degrees
    Nov 2005
    219
    Quote Originally Posted by highmikebart View Post
    1.025-.875=.150
    .593-.518=.075
    X moves twice as much as Z so it is a true 45 degree angle.
    Jan 2008
    6
    Quote Originally Posted by Eurisko View Post
    = arctangent (-1)
    = -45 degrees
    I want to thank you very much for the help. Your response was much appreciated. Thanks again!
    Jan 2008
    6
    Quote Originally Posted by theemudracer View Post
    1.025-.875=.150
    .593-.518=.075
    Thanks so much for your response! It was very helpful!
  1. Student Pricing?
    By rlrhett in forum Mach Software (ArtSoft software)
    Last Post: 08-05-2020, 08:32 AM
  2. Student Here
    By FAMOUSX1 in forum Education - Teachers and Students Hangout
    Last Post: 04-23-2007, 05:24 AM
  3. Can anyone help a 42 old student with a project?
    By mike wise in forum G-Code Programing
    Last Post: 11-19-2006, 09:49 PM
  4. I want to be a CNC student
    By praetor in forum MetalWork Discussion
    Last Post: 10-02-2005, 11:11 PM
  5. Pro/E student pricing
    By jcolley in forum PTC Pro/Manufacture
    Last Post: 03-03-2005, 12:57 AM
