585,717 active members*
4,051 visitors online*
    Feb 2006
    57
    Feed rate Ovverride also Increases rapid rate.
    When I use the feed rate ovveride it increases the rapid and euqal amount. for example if increase a feed rate from 4 to 6 IPM then my rapid icreaes from 60 to 90 IPM.
    Must be some box I need to uncheck or something EH.
    Try "No FRO on queue" in the general config. But be aware that this may cause a delay in the FRO. The recommended method is to increase the feedrate in your g-code and use the FRO to slow it down.
    Some development work is currently being done to the FRO, expect some changes there in the near future.
  1. O mate M slow rapid rate
    By diemaker in forum Fanuc
    Last Post: 10-06-2013, 08:04 PM
  2. Feed Rate and Spindle Rate for this cut?
    By DroopyPawn in forum MetalWork Discussion
    Last Post: 11-22-2007, 06:12 AM
  3. O mate M slow rapid rate Phase II
    Last Post: 10-18-2006, 10:08 AM
  4. Feed Rate?
    By bearwen in forum Uncategorised CAM Discussion
    Last Post: 04-26-2006, 10:52 PM
  5. C & Z Feed rate
    By rfstar in forum G-Code Programing
    Last Post: 06-22-2005, 06:38 AM
