585,722 active members*
4,228 visitors online*
Results 1 to 8 of 8
    Aug 2005
    13
    Milling soft cushioning foam?
    i've seen a few of you guys cnc milling/routing poly foams and such..
    i'm curious. do you think you could also cnc soft cushing foam? the spongy type?
    thoughts?
    joe
    Jan 2006
    738
    Soft foam
    I have hot wire cut soft foam with some success. Really smelly and not a smooth operation. A band saw does a much smoother job. How large are the pieces you intend to cut? Do you need 3 axis or just 2?
    Steve
    Aug 2005
    13
    more so for cutting out 3d shapes like a regular cnc router..
    Jun 2007
    3757
    Lightbulb Freeze it?
    Dry ice or liquid nitrogen (take a vacuum flask to your supplier. Good fun. Be careful of skin contact though.)
    Feeze it. Now you can machine a solid.
    Jan 2006
    738
    Ditto
    Exactly what I was going to suggest. You will have to freeze it to keep it from catching and wrapping if you plan to use a router. I understand that there has been some success on soft material using a burr type tool in a very high speed (50K rpm) spindle.
    Best of luck
    Steve
    Aug 2005
    132
    I'm no expert on this but I know someone that has done this.
    He told me the trick is to use a sharp multi flute cutter.
    The one he showed me was a 10mm 10 flute cutter.
    The numerous flutes doesn't give the foam time to compress before it is hit with the next one.
    Cheers
    Rod
    Jun 2007
    32
    Soak it in water, then stick it in your freezer. It will be like machining a block of ice. It will keep the cutter cool as well. Hopefully you are done before it melts!!
    Jun 2003
    453
    If you freeze it make sure you take measuremets of the block of foam before and after freezing it to see what happens in regard to thermal contraction, you may need to scale your cad dimensions depending on the acuracy required.
    Splint
  1. Anyone tested milling soft aluminium with Joes CNC?
    By Viperia in forum Joes CNC Model 2006
    Last Post: 10-11-2007, 03:10 AM
  2. Foam & Wood milling machine
    By perolalars in forum DIY CNC Router Table Machines
    Last Post: 04-11-2007, 05:42 PM
  3. endmill specs for foam milling ?
    By max_imum2000 in forum CNC Wire Foam Cutter Machines
    Last Post: 12-28-2006, 10:33 PM
  4. High Speed CMS FOAM 5-axis milling machine
    By fairlane77089 in forum Hard / High Speed Machining
    Last Post: 06-05-2006, 04:09 PM
  5. Milling Foam- Speeds/Feeds
    By JerryFlyGuy in forum Material Machining Solutions
    Last Post: 11-21-2005, 05:02 PM
