584,865 active members*
4,963 visitors online*
Results 1 to 6 of 6
    Dec 2007
    341
    Unhappy mach 3 jogg problem
    hi everyone.problem is this .when i jogg it will go a little ways and stops and then you loose the function to the keys .The only way to get going is to reset and try it some more but then it does it all over.i have reinstalled several times same deal.anyone have any ideas?
    Jan 2007
    869
    What kind of controller do you have?
    Wade
    Jun 2006
    217
    What is it? the machine? Do the DROs stop?
    Nick http://www.nixstuff.com
    http://www.youtube.com/watch?v=jTu7wicVCmQ
    Oct 2012
    17
    Re: mach 3 jogg problem
    Is anyone familiar with this "problem". :-)
    When I press arrow key to move ( for example) in Y+ direction and at the same time press other arrow key to move to the X+ dir, the machine does not respond to X+ command , and continius to move only in Y+ dir. This started to happen recently, and since then I can not move gantry diagonaly !?.
    To be more precise, I can run machine diagonaly , but only in the direction : Y+ / X-, and in other cases the machine goes only in the direction that the arrow key pressed first.
    Z axis works fine.
    Thank you in advance on the suggestions ...
    May 2015
    1422
    I had a similar issue from new on a chinese machine (YongNuo USB breakout) but it went away when I switched to a UC400-ETH ethernet controller + a breakout board. I'd always assumed it was just the cruddy YongNuo breakout that was getting messed up, but now I'm interested to see if it was something else.
    Oct 2012
    17
    False alarm :-)
    The keyboard was full of dust, and caused "problem"
  1. Mach 3 problem
    By vmeek in forum Mach Mill
    Last Post: 09-06-2011, 07:42 PM
  2. mach 3 problem
    By ellard in forum Machines running Mach Software
    Last Post: 04-16-2009, 12:53 AM
  3. mach 3 problem
    By ellard in forum Canadian Club House
    Last Post: 04-15-2009, 06:01 AM
  4. Jog problem with Mach 2
    By jtriggs in forum Mach Mill
    Last Post: 06-15-2006, 06:48 AM
  5. mach 2 problem
    By cncadmin in forum Mach Software (ArtSoft software)
    Last Post: 01-16-2005, 09:12 PM
