584,865 active members*
4,814 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > Haas rotary/indexer controller protection
Results 1 to 7 of 7
    Jun 2007
    44
    We have Haas rotary/indexer controller box and some of the parameters are protected. Is there any way to unlock the protections. I know that you have to call Hass to get ther code. Is there any way without call ing them? Any formula?
    Apr 2007
    178
    parameter 30 times 1027 then convert to hexadecimal then invert the last 2 pairs to the right of numbers ie: if you end up with 1b52then make it 521b then take this number and convert to decimal then type the result into parameter 30 immediately goto parameter 24 and subtract 8 to keep the lock off.
    REYTECH Machine Service Corp. CNC repair NY, NJ
    http://www.reytechmachine.com
    Dec 2009
    Re: Haas rotary/indexer controller protection
    This works -- Thank You !!!!!! - i have a haas s5c rotary indexer
    Mar 2008
    638
    Lol. Ah, fun times
    Dec 2013
    I couldn't get this to work. I have an old box from 2004. It has 5 digits in the parameters and I keep getting an 8 digit code with this formula.
    Apr 2018
    I am having the same problem as Steve.s
    Can anyone tell us how to do this on an older unit with no letters on the keyboard and only 5 digits in the parameter?
    May 2011
    5
    Quote Originally Posted by serviceman View Post
    Hi
    I need to modify parameter 20. but this procedure does not work for me.
    -- I convert the value in parameter 30 to hexadecimal
    -- in the hexadecimal number I move the two digits as you explain
    -- I convert the new hexadecimal number to decimal
    -- the decimal number is written in parameter 30 (but writing it does not keep the value)
    -- and in parameter 24 it does not allow me to modify the value
    regards
  1. haas rotary indexer
    By beno68 in forum Community Club House
    Last Post: 12-06-2013, 08:20 PM
  2. Replies: 1
    Last Post: 10-05-2011, 02:39 PM
  3. Rotary Indexer Help
    By GM81 in forum Fadal
    Last Post: 05-03-2011, 04:12 PM
  4. Overload protection on a Rotary Phase Converter?
    By CATCH22 in forum Phase Converters
    Last Post: 07-25-2009, 03:13 PM
