The other day I posted a similar question in another part of the forum, and with a couple more days of reading under my belt, I have refined my search.
Here are the things that I would like to have in a lathe:
-At least a 14" working area (swing is not important because I doubt I would ever go over 4")
-Power feed, though I don't necessarily need it on the cross feed, though that would kick ass
-Lower speed range for threading, like 60-120 up to anything above 900/1k.
-Decent torque, so if I ever wanted to cut a course thread at low speed I could.
-Enough Strength to Knurl a basic diamond pattern (aluminum, maybe steel)
-at least a couple inches of the tail stock's cylinder's travel. (sorry about the vague terms, but for drilling/reaming etc.
-The ability to change speed w/o tearing the machine apart. (I am not sure about this, but it seems that most smaller lathes, to change your speed you have to move all the gears around, correct me if I am wrong)
I will be using it for this:
I am a jewelry/machining student and will be using this for the next 5-ish months and during breaks away from school when I don't have access to their facilities.
I would like to be able to turn ti, stainless, mild steel, wax, and aluminum. (can one turn anything harder, like a tool steel?)
the 14" center to center is needed because some of the stock I would get is probably 1.5" and a foot long, yes I could cut it down, but it would be nice not to have to...
I would be mainly turning rings and that sort of thing...but I may need to make a tool every now and again.
So, does such a beast exist?
Also I am curious about the 3 in 1 machines. Most people on these forums bash em, but since most of you guys are working with other chinese made machines, what is your take.
Regardless of that, how strong are those milling attachments, or other mini mills? What is the largest hole that can be drilled with one of these? (of course being smart about it, plenty of oil, nice bits, and taking your time pecking through and clearing chips)
With any 3-in-one or separate mini mill, I would want to be able to work will all the same materials.
Thanks for any help you guys might have, as these are the questions I have not been able to find answers to so far in my hunt.
Oh yeah and I doubt I would ever get around to setting one of these up CNC, but if it does a nice job, maybe. And if I could toss a DRO on one, thats a plus...
Thanks again,
Julian
