585,743 active members*
4,887 visitors online*
IndustryArena Forum > WoodWorking > WoodWorking Topics > Torsion box design in depth info?
Results 1 to 7 of 7
    Mar 2005
    1673
    Hi all,
    I’ve just spent almost an hour tiring to find in depth information on torsion box design and not got very far. I’m hopping some one has the time to post links to good information.
    I have built many things using torsion boxes and have to admit they have been designed using just my common sense. I would like to be able to design using some established principles such as rib, skin thicknesses and rib spacing.
    So any useful links would be very much appreciated
    John
    http://www.diynetwork.com/diy/shows_..._26946,00.html
    http://thewoodwhisperer.com/episode-...e-torsion-box/
    Not sure how much info those links have. I bought a magazine a few months ago with an article on torsion boxes, but it didn't really have any technical info. Woodworkers Journal June 2007. It mentioned that rib spacing should decrease as skin thickness decreases. Rib thickness didn't make a lot of differrence, but strength was related to the glue surface area between the ribs and skins. Which would mean the thicker the ribs, the stronger the box. But I don't think you need to go with anything wider than 1/2" for the ribs.
    Mar 2005
    1673
    Thanks very much for the links, I’ll take a look :cheers:
    Dec 2005
    1408
    Dear Oldmanandhistoy,
    Try searching "stressed skin panel". A "torsion box" is a stressed skin panel in two directions. Structural calculations for stressed skin panels are well explained in "Timber Designers Manual" by Ozelton(?) and Baird. It is BTW, the most fantastic book.
    Best wishes,
    Martin
    Mar 2005
    1673
    Quote Originally Posted by martinw View Post
    Best wishes,
    Martin
    Thanks Martin,
    Your recommended search gave me this on the first page, which at first glance looks very promising.
    http://gp.com/BUILD/DocumentViewer.a...elementid=3815
    Regards,
    John
    Btw please just call me John
    Dec 2005
    1408
    OK John....
    Dear John,
    There is a PM for you. Borrow my copy of Timber Designers Manual if you want.
    Best wishes,
    Martin
    Mar 2005
    1673
    Dear John,
    Best wishes,
    Martin
    Thank you
  1. Torsion box question
    By chuckknigh in forum DIY CNC Router Table Machines
    Last Post: 12-27-2010, 04:47 AM
  2. How to make a Torsion Box the Right way!
    By Regnar in forum DIY CNC Router Table Machines
    Last Post: 06-06-2007, 05:18 PM
  3. Charge Pump DIY Info, Circuit, Design, PCB???
    By HayTay in forum CNC Machine Related Electronics
    Last Post: 07-09-2006, 03:47 PM
  4. 80/20 torsion box and router design
    By KTP in forum 80/20 TSLOTS / Other Aluminum Framing Systems
    Last Post: 03-01-2006, 04:24 AM
  5. Torsion box discussion
    By posix in forum Mechanical Calculations/Engineering Design
    Last Post: 02-04-2006, 06:04 PM
